fault codes
Old Nov 29, 2014 | 04:18 PM
pappy's powerstroke's Avatar
pappy's powerstroke
fault codes
Hey guys, New member here...My check engine light came on and so I had it scanned and the following codes came up...PO 672 674 676 678...Glow plugs for cyl. 2,4,6, and 8...
My question is...Is there a relay for these cylinders and is that the problem?
Pretty sure all four glow plugs would not go bad all at the same time...There is some type of box mounted above the valve cover on the right bank...Is that it?
I'm pretty sure this truck originally came from California.
2002 F-350 dually crew cab 7.3 Powerstroke
Old Nov 29, 2014 | 04:30 PM
ToMang07's Avatar
ToMang07
Is it idling rough at all?
The GPCM is a problem child. That said, if it's running rough I'd bet it's your driver's side UVCH, Unver Valve Cover Harness.
Old Nov 29, 2014 | 08:47 PM
pappy's powerstroke
Thanks for the reply....It is not running rough at all...When I had it scanned, they cleared the fault and it came back on later that day (Tuesday) and has been on ever since...Drove it this evening and it did not come on...
Thanks for any help...Hate to buy a part and put it on and that is not the problem...
Old Nov 29, 2014 | 08:57 PM
tonym17's Avatar
tonym17
check to make sure the plugs going into the valve covers are secure and plugged all the way in
bwguardian
Feb 20, 2018 02:40 PM
f2504x4man
Dec 30, 2013 11:15 PM
Turfzilla
Nov 19, 2012 06:42 AM
dcorry
Nov 19, 2010 08:58 PM
wilbur996
30
Nov 15, 2008 02:13 PM
