460 swap
Old Jul 18, 2003 | 10:38 AM
travis c's Avatar
travis c
460 swap
i have a 76 ford f100 with a 351m in it and a 3 speed manual trans, would a 460 bolt up to that trans? what kind of hp would i be looking at?
Old Jul 19, 2003 | 11:17 AM
qtrmiler's Avatar
qtrmiler
460 swap
Bolts up to the trans but the converter is different as are the mounts. A 460's HP depends a lot on what it comes out of... got a donor in mind?
Old Jul 20, 2003 | 10:23 AM
Brian460's Avatar
Brian460
460 swap
There is no converter since it is a manual transmission, and on that note I don't know if that tranny can take the hp and torque a 460 is able to produce. Maybe somebody else will step in and tell us.
Old Jul 20, 2003 | 11:05 AM
qtrmiler's Avatar
qtrmiler
460 swap
You can use the bellhousing & trans. The flywheel will bolt up but it's not balanced the same.
Old Jul 21, 2003 | 10:02 AM
Steve_Uzi's Avatar
Steve_Uzi
460 swap
Make sure you check the Pilot bearing size! Especially if the 460 came out a car with an automatic tranny. The 429/460's had 3 different size pilot.
Measure the OD of the manual tranny shaft and the ID of the end of your crank!
Old Jul 21, 2003 | 04:23 PM
ranger429's Avatar
ranger429
460 swap
why would you want to put a 3 speed behind a 460? i would look for a 4 speed donor trans from a big block and get the flywheel while you are there
Old Jul 21, 2003 | 10:51 PM
Brian460's Avatar
Brian460
460 swap
That is not accurate since there is a bushing or bearing that will need to be installed in the crank for the input shaft to ride on.
Old Jul 22, 2003 | 06:28 AM
Steve_Uzi's Avatar
Steve_Uzi
460 swap
Well, it is true in a sense because you will need to get the Correct bushing for your crankshaft.
Old Jul 24, 2003 | 01:18 PM
Brian460's Avatar
Brian460
460 swap
Sorry bout that Steve somehow I totally missed the part about the pilot bearing.
That is an entirely true statement.
Old Jul 24, 2003 | 06:45 PM
Steve_Uzi's Avatar
Steve_Uzi
460 swap
no biggie, as long as the guy gets the info he needs no need to apologize
