Engine Transmission Swap
Old Nov 28, 2014 | 10:12 AM
Davie J.'s Avatar
Davie J.
I'm rebuilding my '87 F250 Laredo with a highly modified 5.8 liter engine and a ZF S5 42 transmission. I have several questions that one of you might know the answers to: First, will the transfer case from my old C-6 transmission fit on the new ZF? Second, will the cross members from the old C-6 work with the ZF? What all do I need to support the 5.8 liter engine and ZF transmission? Third, what is the length difference between the 460 with the C-6 and the 351 with the ZF? Will I need to machine the drive shaft?
Old Dec 3, 2014 | 08:02 PM
UNTAMND's Avatar
UNTAMND
Yes the transfer case will bolt to your zf trans.
Not sure in crossmember location but that's not hard to alter.
Driveshaft length, beats me. I doubt it's going to stop you from doing the swap, so either someone will know, or you'll figure it out at the end of your swap.
If the old engine was a 460, then it has the dual bolt hole frame mounts. I'm not sure that it's compatible with the single bolt mount of the 351, so you may need new frame mounts. Otherwise, the crossmember for trans only needs a few holes to move it where it belongs.
Old Dec 5, 2014 | 03:23 PM
Davie J.'s Avatar
Davie J.
Thanks for the info. Now if the shifters will come up at the right place, I'll be OK.
evan_nugget
Apr 24, 2018 05:46 PM
89 F250
Sep 19, 2012 04:38 PM
masterguns2003
Jan 23, 2007 10:25 AM
fear begins wiht fe
Jan 5, 2005 02:57 PM
RTM
Dec 6, 2003 07:37 PM
