It is time to replace my air filter and I am curios what everyone uses and why.
I have noticed than my 300 i6 runs better with the lid off the filter, so I was considering a high flow re-usable filter. Are they worth the extra cost?
I am not opposed to swapping out the stock breather so don't limit discussions to what will fit in there. It is missing the snorkel anyway.
Thanks
As far as I know Greg,you plan on keeping your 300 stock. So it won't be spinning any high RPM. I have the washable filters in my Supercharged Harley F150 and my 4.6L cougar. But not in my 460 Bump and I don't think you need one either. The washable ones are fine for an engine that is spinning fast and wants to breath but not for us IMHO. And plus you still have to buy the Recharger (cleaner) kits for 'em about every 3rd clean. I'd buy an open element Chromie if you find one with the small I.D. to fit your carb OR buy a QUALITY paper filter that is approx. an inch taller than your present one. That will raise your factory lid up and straighten out the airflow entering your carb.
You are correct, my 300 is stock and will remain close to that.
As far as the paper filter, what do you consider a 'Quality' brand? I currently run a Fram Air filter.
Fram is OK. I just meant one of those no-name cheapies. The cheapies don't have near the same amount of pleats. Which means far less paper area. If you give me the dimensions of your current filter I'll see if our Ford Motorcraft Filters book will give us a filter part number you can use. The "air filters listed by size" chart in it isn't near as long as it used to be. You can them find a Motorcraft filter or have a parts store cross that number over to fram.
I recommend a 14x3 paper filter using an open element air cleaner housing. Mustangs Plus sells a Hi-Po repro with the correctly stamped flat lid for about $35.. it even has a Ford blue base. Apply an arched engine displacement decal and you'll be golden. http://www.mustangsplus.com/xcart/19...r-Cleaner.html
Most aftermarket lids (like Edelbrock and Holley) have a sloped lid which caters to and more correct appearance for the GM crowd.
my current housing has the hump in the base to clear the manual choke. Will that one clear it?
Not a fan of chrome but could scuff and paint it Ford blue
I have an I-6 and had my nads wrung so tightly years ago that it still hurts. I suggested that I replace the oil bath that I have with a modern paper filter.
The upshot:
You can do no better than the stock oil bath from the '60's era for the 1-V original carburetors. Once a year you dump the oil replace for the price of a quart of oil. One unnamed individual on the site even uses his wife's filtered cooking oil to save a buck. He is right.
Paper filters were the dealers' way of peeling cash from you at service time.
Jeff and the ND will be in soon to sound off on this issue.
A happy and peaceful Thanksgiving to all of you that have brightened my life and made me laugh.
The upshot:
Semper Fi
You're 1/2 right John. Here I am but not to say what you thought. I respectfully disagree with you on the oil bath air cleaner. It doesn't filter 100% of the air going in the engine. When I was in vocational Auto Mechanics class in high school ('73 1/2 to '75) we did some class time and shop time. One day in class time my teacher showed us a movie about this very subject. They showed in this movie this guy put one heaping silver teaspoon of sand down the carb of a running engine. I don't remember the RPMs. IT MESSED UP THAT ENGINE!
