Sponsored by: Auxito
Confusing Electrical Issue
Old Nov 25, 2014 | 09:41 PM
Rottsailor's Avatar
Rottsailor
I have had a reoccurring problem while trying to start my 1998 F-150. Lately when I get in to start, there is a click then nothing. I mean you put in the key, turn to aux position and everything lights up and power is good (instruments, radio, voltage good, etc). Continue to turn to start and there is a click and then no power to anything. The truck behaves like a dead battery. However the battery is good. The trick to starting is removing the negative terminal from the battery and basically resetting the system. Once I do this, the truck will start once. If I turn it off and try to restart, then I need to reset again.
There is an electrical problem somewhere and any advice on where to look would be appreciated. The battery and fuses are good, but I'm thinking some sort of short being caused somewhere.
Mahalo!
Old Nov 25, 2014 | 09:52 PM
JWC 3's Avatar
JWC 3
Sounds like you have a problem with your battery cable or ends . If you have an aftermarket bolt on cable end , they can corrode where the cable clamps in . Check All connections for corrosion .
Old Nov 25, 2014 | 10:10 PM
Rottsailor's Avatar
Rottsailor
Thank you for the info. The cables are corroded so I will go clean them up and see if that helps.
Thanks again.
Old Nov 25, 2014 | 10:25 PM
JWC 3's Avatar
JWC 3
Best of luck . Let us know what you find .
OldMontanaFord
Dec 9, 2017 11:11 AM
evan_nugget
Nov 20, 2017 12:37 PM
imsorope
1983 - 2012 Ranger & B-Series
Jan 4, 2012 08:57 AM
keyul
Oct 29, 2007 02:05 PM
RAK1
Nov 23, 2003 06:35 PM
