Ford Excursion Barn Door Latch Bolts
Old 11-25-2014, 11:48 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Originally Posted by aaedin
Alrighty, I'll work on cleaning them up tonight. Thanks Boltmaster... meh thanks Matt
There, fixed that for ya
Old 11-25-2014, 11:50 AM
Apocalypse's Avatar
Apocalypse
Matt, you do anything with my 5.4? I'm looking for a sub 10sec X...
EDIT: Full interior, OEM running gear (like that would hold up), and OEM suspension on AT tires.
Old 11-25-2014, 11:52 AM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
How much money you wanna spend. Cuz right off the bat I'm thinking use the existing body as a mold and make a carbon fiber replacement. The weight savings alone...
Chevelle just did 10.29 @ 128mph, comes out to 5.42hp/lb, using a borrowed 496 that my friend just finished but his vehicle isn't ready. Had to see what it could do, lol.
Old 11-25-2014, 11:55 AM
Apocalypse's Avatar
Apocalypse
Honestly with an aluminum or full CF body we would drop 1/4-1/3 of the weight... I hadn't thought of the body at all... I can't even imagine the difference that would make on the X. I mean you could just drive an F-150 with the 5.4 but it wouldn't be the same.
Apocalypse's Avatar
Apocalypse
Originally Posted by Krazee Matt
How much money you wanna spend?
Less than it would be to buy a 6.0
Old 11-25-2014, 11:57 AM
Krazee Matt
Then no. Between motor, upgrades, fuel system, tuning, transmission and related driveline components? No way.
Old 11-25-2014, 12:07 PM
Apocalypse's Avatar
Apocalypse
Awwww what if you use one of these?
http://www.ebay.com/itm/100-PERFORMANCE-SPEED-CHIP-FUEL-GAS-SAVER-FORD-F-250-F250-V8-V10-GAS-DIESEL-/181592517924?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a47c1ed24&vxp=mtr
Or 10.... then I could blow that little 1kHP car of yours out of the water
Old 11-25-2014, 01:39 PM
Krazee Matt
It's runs an 8.0-8.3 @ 167-173 spread depending on air, good luck with that lol.
Old 12-02-2014, 11:31 AM
aaedin's Avatar
aaedin
aaedin is offline
Thanks!
Oops, I don't think I ever said thanks for the help. Thanks for the help FTE. Less than $5 at ACE hardware, one side done so you can see the difference. Stainless this time around.
Old 12-02-2014, 01:24 PM
Apocalypse's Avatar
Apocalypse
Those look GREAT! Thanks for posting up your results
Old 12-02-2014, 01:56 PM
aaedin's Avatar
aaedin
aaedin is offline
anytime Boltmaster
Old 12-02-2014, 04:51 PM
Krazee Matt
Agreed, they look way better.
Now I'm wondering if I can fit LED tipped bolts in there... hmm.
  #28
Old 12-02-2014, 06:40 PM
Apocalypse's Avatar
Apocalypse
No need. I found (and still haven't done) this a few months back:
http://www.ultimateyota.com/showthre...s-2000-4Runner
  #29
Old 12-02-2014, 06:46 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
I also replaced mine with stainless long ago.
df85732
07-01-2018 04:49 PM
schoo
04-03-2017 10:21 AM
7636074460
11-26-2012 11:09 PM
learpilot
09-27-2005 09:24 PM
Scott123
11-24-2003 12:41 PM
Quick Reply: Ford Excursion Barn Door Latch Bolts
