Aussie John
Old Nov 24, 2014 | 07:01 PM
JohnAussie's Avatar
JohnAussie
Smile Aussie John
Hello
Been following the site for quite a while and would love your help.
We have a 2002 F250 XLT. Having a problem, the truck was left sitting for three months and when I drove it again got back home put into park, the reeves increased and the OD light on gear change started to flash.
Had the codes checked and they replaced the map sensor. Drove home put into park and the same happened. There does not seem to be anyone in Aus who can help.
had 50 hp towing chip and gearbox chip fitted 7 years ago. Gear box chip supposed to increase line pressure from 95 psi to 126. Gear change is the same.
Would appreciate any help you guys can help with.
Cheers JohnAussie
Old Nov 24, 2014 | 11:20 PM
r___r's Avatar
r___r
Welcome to the forum John,
There's a couple of forums on here that applies to your truck. Go there and ask some questions and I'm sure you will get some good advice there.
Good luck
Old Nov 25, 2014 | 08:58 AM
1Aauto's Avatar
1Aauto
Former Vendor
Thanks for joining John, it's great to have you here.
Old Dec 6, 2014 | 03:48 AM
Frank_Ford's Avatar
Frank_Ford
Hi John,
Great to see another member from Down Under!
As the guys suggested, have a look at the other forums section of the site which will be able to point you in the right direction for your question.
Enjoy and all the best.
Cheers
hanklin
Mar 13, 2010 12:49 PM
Straight Six
Feb 26, 2010 06:47 AM
rebocardo
Aug 2, 2003 10:44 PM
