2.3 replacing a 4.0
Old Nov 24, 2014 | 12:32 PM
vintagequest's Avatar
vintagequest
2.3 replacing a 4.0
Hi all. I currently own a '94 Ranger I inherited from my dad quite a few years back. Unfortunately it has a cracked head among other engine related issues. Sitting in the corner of my garage is a "fresh" 2.3 which came out of my '85 Capri. Currently the Ranger is a 4.0 automatic with a good tranny. What (if anything) is necessary to fit the 2.3 to the 4.0 tranny? I've tried to research my query on the internet but seem to find every combination BUT. I know not many would downsize the engine size but this truck is otherwise in such great shape and would like to use it for my 80 mile daily trip to work & back. Admittedly, the 4.0 wasn't really that great with fuel mileage. Thanks in advance. -Alan-
Old Nov 24, 2014 | 02:33 PM
nlassley's Avatar
nlassley
Is the 2.3 efi or carbed?
Old Nov 24, 2014 | 05:14 PM
vintagequest
It's carb'd. I know how to switch a system from injection to carb but I'm at a dead end with driveline matching info. I'm an old school kinda guy. Something with a carb and Duraspark is something I am more comfortable working on.
Old Nov 24, 2014 | 09:30 PM
nlassley's Avatar
nlassley
I might be wrong but I think you can swap in a bellhousing from a 2.3 a4ld If you have a 4.0 a4ld but the biggest issue will be with the electronic controls.
Ford Ranger Automatic Transmission Identification
Old Nov 24, 2014 | 10:04 PM
Old93junk's Avatar
Old93junk
Sell the 2.3 and buy a good used 4.0............You will be way ahead in $$, stress and busted knuckles.
Old Nov 27, 2014 | 10:53 AM
Conanski's Avatar
Conanski
This swap isn't going to work, the Briggs&Stratten(2.3L) will not bolt to the 4.0L trans and the bellhousing is not detatchable so you would need another trans. Then you would have to change the head on the 2.3 to an EFI head and find a complete '94 EFI intake, wiring harness, and PCM for it and swap all that in... which may or may not be a simple plug and play operation. You can forget converting the truck to a carb unless you replace the trans with a manual, the auto that is currently in there is controlled by the PCM and it won't work at all without all the EFI engine sensors plugged in and operational. And with all that done you would have a truck that would be so gutless that it can't get out of it's own way.. the old Crapi motor makes a wopping 88hp!! So yes it'll get better fuel milage than the 4.0L but you will absolutely hate driving it.
clunker86
Engine Swaps
Mar 13, 2010 01:51 AM
mattri
4 Cylinder Engines
Jun 4, 2009 02:01 PM
fordnut forever
Nebraska Chapter
Mar 8, 2008 07:46 AM
ranger721
Jan 12, 2008 04:38 PM
Brilac
Engine Swaps
Feb 7, 2006 06:58 PM
