Sponsored by: Real Truck
Transmission Trouble
Old Nov 21, 2014 | 11:56 PM
JM 2005 F350's Avatar
JM 2005 F350
I have been having some inconsistency with my transmission in my 2005 F350. I bought it used 2 months ago and have had the low/tow overdrive light blinking. a month ago I removed the pan and changed the filter in the transmission. I had a friend run the diagnostic test and found transmission solenoid code as well as both cat. converters (California) as well as my Number 8 cylinder misfiring... I pulled the transmission pan and filter to find what appears to be 7 solenoids??? The cost for 1 solenoid was $129.... any advice on where to start?
Old Nov 22, 2014 | 12:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The place to start is with the engine problems. Fixing the engine problems often fixes the transmission problems.
And you need to change the remote transmission filter near the radiator. The one in the pan is a lifetime filter.
BlackTruckDave
Oct 4, 2018 10:27 PM
08F250SD_Laredo
6.4L Power Stroke Diesel
Mar 14, 2018 11:26 AM
AGE mechanic
Jul 19, 2012 07:54 PM
429PI IN 75 f-100
Oct 28, 2011 11:20 PM
OSBUCKEY
Oct 20, 2009 09:39 PM
