bad vibrations
Old Nov 21, 2014 | 12:07 AM
bert cook's Avatar
bert cook
bad vibrations
my 81 f100 just started a new trick that I don't like.i put it 4th gear it and it bucks and viberates i checked the universals and they are good the only thing I have found is some slop in the yoke on the rear end.... 1st thru 3rd are normal
Old Nov 21, 2014 | 04:24 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What gearbox do you have Bert?
Old Nov 21, 2014 | 08:34 PM
bert cook's Avatar
bert cook
toploaer 4speed originally in a 82 3/4ton 2wd
Old Nov 22, 2014 | 08:12 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Is it a cast iron or aluminum top?
Old Nov 22, 2014 | 09:05 PM
bert cook's Avatar
bert cook
the top is cast iron
Old Nov 22, 2014 | 10:36 PM
Gary Lewis's Avatar
Gary Lewis
It is possible that you have an ignition problem. High load at low RPM puts max stress on the ignition components, so if something is failing, like plugs, plug wires, rotor, or dizzy cap that's when it would do it.
Old Nov 23, 2014 | 12:28 AM
bert cook's Avatar
bert cook
that's a definite possibility im way overdue for a tuneup
Old Nov 23, 2014 | 04:53 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm going to assume T-18.
That gearbox is 1:1 in top.
I don't think there should be a reason for it to cause this.
Are you lugging the engine in 4th gear?
Old Nov 23, 2014 | 09:16 AM
Gary Lewis's Avatar
Gary Lewis
Try winding it up a bit more before you shift into 4th and see if it does it. The ignition scenario rears its head, as Jim suggested, when you are lugging it.
Old Nov 23, 2014 | 07:16 PM
bert cook's Avatar
bert cook
the cure for this problem was a tune up one oil fouled plug and one burned plug wire replaced it running great you nailed it gary
Old Nov 23, 2014 | 07:29 PM
Gary Lewis's Avatar
Gary Lewis
Good! Glad it worked out that easily.
gatorman55
Mar 7, 2016 04:43 PM
Josh726
Jun 25, 2015 08:29 PM
76EconolineND
Mar 30, 2008 06:33 AM
Ricky St. John
May 18, 2004 05:00 PM
jeffdoerr
1997 - 2003 F150
Apr 12, 2004 09:30 AM
