Been keeping low profile as I research about the V10. The only question I have not really seen any extensive information on is if a small amount of the correct loctite on the plugs when torqued has given any aid to reducing the plug spiting as they loosen over time. Hope I didn't over look this but if I did please direct me to the correct topic.
Modular Motor plugs most likely tend to loosen up due lack of proper torque during installation. By that I mean 21-23 lbs/ft instead of the factory recommendation of 7-14 lbs/ft.
I also use nickel-based anti-seize and change plugs at 50K rather than the 100K they're said to last. While this might bring about disagreement from others its worked flawlessly for me as well as a few others too.
BTW my experience is based upon the 2 valve versions of this engine.
2 valve is the basis of my question. Thanks for the informative feedback. Don't see any negatives to buying a used V10 Excursion.
After that I've followed my settings and never had a single issue. YMMV of course.
that is the first time ive read that, i personally have never stripped a v10 but did have one on my mustang blow out, but i already owned the tools for it ahd bought them as a precaution that i didnt know i would need, i may try your specs
To me the proper torque wrench is key to steel plugs in aluminum heads---I have a Wright 3/8" model that's used for nothing but these plugs. Its probably the most well cared-for tool I own despite it's quite a bit less expensive than many others in the tool box.
The other school of thought using factory torque but re-checking at 5-10K mile intervals never made a lot of sense to me. Then again I change plugs at 50K regardless claims they're good up to 100K.
I can't claim I've changed plugs hundreds of times but so far my specs---derived completely from FTE---have worked just fine.
