Please help me
Old Nov 19, 2014 | 07:04 AM
90slover's Avatar
90slover
Please help me
Dear fellow FTE's. I need in great detail if possible about getting a 94 5.0 transmission working correctly with a 93 4.9 engine. My problem is that when trying to shift out of 2nd(this is an automatic transmission) it will not go into 3rd. around 35-40 mph when hitting throttle it goes whommmmmmm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! and will not let off of it until u drop below 30mph. please help this project truck. it has been a 8 month project and i cant do it no longer. winter is hitting in missouri and my car wont last in this.
Old Nov 19, 2014 | 07:27 AM
rla2005's Avatar
rla2005
What transmission is in the truck now? AOD, 4R70W or E4OD.
Old Nov 19, 2014 | 06:33 PM
90slover's Avatar
90slover
The one for the 5.0 I'm not sure how to figure out which it is honestly.
Old Nov 19, 2014 | 11:34 PM
joey2fords's Avatar
joey2fords
lets see if this works ...
Originally Posted by White 97 xlt
It's most likely a C6 or an E4OD...
REAR WHEEL DRIVE
<table border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr> <td align="center" width="25%"></td> <td align="center" width="25%"></td> <td align="center" width="25%"></td> </tr> <tr> <td align="center" width="25%">
AODE/4R70W
16 BOLTS
C-6
17 BOLTS
AOD/FIOD
14 BOLTS
</td></tr> <tr> <td align="center" width="25%"></td> <td align="center" width="25%"></td> </tr> <tr> <td align="center" width="25%">
A4LD/4R45E/4R55E
18 BOLTS</td> <td align="center" width="25%">
E4OD/4R-100</td></tr></tbody></table>
Old Nov 19, 2014 | 11:35 PM
joey2fords's Avatar
joey2fords
by golly it did ... so just go under the truck and examine the transmission pan ... it will look like one of those.
Old Nov 19, 2014 | 11:54 PM
90slover's Avatar
90slover
10-4 good buddy. Shall respond back tomorrow. Currently not near my truck.
Old Nov 20, 2014 | 08:02 AM
rla2005's Avatar
rla2005
Easy Button: Look at the sticker on the b-pillar (aka door jamb sticker) look for the transmission code:
TR= Transmission Code
Code E = E4OD
Code U = 4R70W
I believe the AOD was not an option in 1994. So that brings me back to my original question intent. The 4R70W and E4OD are 100% electronic controlled therefore the best advice is check for codes. If you had an AOD, mechanical/hydraulic, I would suggest to check the TV cable.
Old Nov 20, 2014 | 06:31 PM
90slover's Avatar
90slover
Its the AOD 14 bolt
smandzak
41
May 2, 2023 09:42 PM
justaquestion
Nov 4, 2013 09:13 PM
96_F250_Deezal
All Other Items for Sale
May 2, 2013 11:33 PM
jowens1126
1978 - 1996 Big Bronco
Mar 22, 2013 07:41 PM
Longbed92
Ford Truck Parts for Sale
Dec 6, 2012 09:05 PM
