Torque Spec
Old Jul 17, 2003 | 06:42 PM
trouble's Avatar
trouble
Torque Spec
Can someone tell me what the torque spec for the valve cover are on a 400 Thanks John
Old Jul 17, 2003 | 07:15 PM
shazam's Avatar
shazam
Torque Spec
Tight but not so tight that you make the gasket squish out from under the cover ..
Old Jul 17, 2003 | 08:04 PM
bubbaf250's Avatar
bubbaf250
Torque Spec
Official spec is 3-5 ft lbs. You should re-torque several times until the gasket stops compressing.
Old Jul 17, 2003 | 08:10 PM
trouble's Avatar
trouble
Torque Spec
Thanks Guys
Old Jul 18, 2003 | 01:42 AM
Torque1st's Avatar
Torque1st
Posting Legend
Torque Spec
If you are using sheet metal covers make sure the flanges are flat with a little concave dimple at each bolt hole. The dimple will flatten out as the bolt is tightened. It helps spread the load and avoid gasket "squish out". You can make the dimples with a socket, ball bearing, and a gentle tap from a hammer. -Wear eye protection.
