If you are using sheet metal covers make sure the flanges are flat with a little concave dimple at each bolt hole. The dimple will flatten out as the bolt is tightened. It helps spread the load and avoid gasket "squish out". You can make the dimples with a socket, ball bearing, and a gentle tap from a hammer. -Wear eye protection.
