Checking Block Heater..?
Old Nov 18, 2014 | 09:46 PM
cubinzkid's Avatar
cubinzkid
Hey guys, i'm curious as to how I would test to see if my block heater is working correctly, and which part is broken. I plugged the truck in last night, and went out to start it this morning (13 degrees outside) and didn't notice any difference in start-up, or temp gauge? Wondering how to test, and what parts need to be replaced. Thanks guys!
Old Nov 18, 2014 | 11:59 PM
tecgod13's Avatar
tecgod13
The block heater itself rarely fails, but the cord often has issues.
Testing operation of the system is easy. Shortly after plugging in, you should be able to hear a 'sizzle' from the block heater. The area around the block heater should feem warmer than the rest of the engine.
Check the cord for cracks and breaks in the insulation that could indicate broken conductors. If you have a multimeter, check for continuity between the two blades on the plug. Follow the cord and make sure its still plugged into the block heater (located behind the starter). The place the cord usually fails is right behind the plug as it gets the most flex. You may be able to cut off the plug (and maybe an inch or two of the wire) and put a new end on it.
Old Nov 19, 2014 | 04:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
if the block heater is working, you will feel a warm motor to the touch after being plugged in overnight.
Old Nov 19, 2014 | 05:41 AM
pat420swed's Avatar
pat420swed
ur big hose off the rad should be warm as well, at least mine is after being plugged in overnight, I also get icicles all over the front of my truck from the snow melting off my hood
Old Nov 19, 2014 | 09:39 AM
cubinzkid's Avatar
cubinzkid
Oh, well then she ain't working. Truck is cold as ever in the morning. I'll take a look at the cord. Thanks guys!
Old Nov 19, 2014 | 12:42 PM
jayro88's Avatar
jayro88
I have hear people say that it keeps things warm enough to melt snow off the hood and keep the windshield clear. Mine is functional, but never to this extent. It could be that mine is a van so the majority of the engine is under the dash.
x2 on checking continuity at the plug and insuring that it is plugged into the block heater. Mine was unplugged as well as a damaged cord. Repaired the cord and it has been golden for 3 winters now.
Old Nov 19, 2014 | 12:55 PM
mtcox's Avatar
mtcox
Block Heater
Jayro88,
Does your motor have two heaters? The 460 in my 1995 F250 has two; one on each side of the block. You may want to install another one on the opposite side of the original. It's a big piece of metal to be heating!
Old Nov 19, 2014 | 01:49 PM
PB1976's Avatar
PB1976
I use a glue on pad that heats the bottom of my oil pan, warms the oil, and since heat rises....................well you get the idea.
I spliced the cords together so its just 1 plug in, and now the original block heater and the oil pan pad are both on.
Its not a big engine, just a 5.4 in an F150, just an idea I thought I would throw out there is all.
Old Nov 19, 2014 | 01:53 PM
PB1976's Avatar
PB1976
Old Nov 19, 2014 | 01:54 PM
PB1976's Avatar
PB1976
Old Nov 19, 2014 | 02:41 PM
madpogue's Avatar
madpogue
100-125 watts is going to provide very little additional heat. Esp. through the pad, through the metal of the oil pan. And it certainly won't make up for an inop stock block heater. Even those old magnet heaters that you'd "stick" to the oil pan were 200-300 watts.
The stock element block heater is 1000 watts, and if it's working, should provide plenty of heat directly to the coolant. Instead of speculating and window shopping, TEST it. Measure the resistance at the grille plug. Between the two blades, should be about 14-15 ohms. If it's "open" (infinite resistance), or much higher resistance than 14-15, disconnect the cord at the element, and measure resistance between the two round terminals right at the element. If it still shows high or "open", then the element is faulty. If it shows correct (14-15 ohm) resistance, then the cord is suspect/faulty.
Old Nov 19, 2014 | 02:53 PM
PB1976's Avatar
PB1976
I use mine WITH my block heater and its a HUGE help.............it is not a replacement for a block heater.
The warm oil sure makes starting nice at 30 below though.
Old Nov 19, 2014 | 03:54 PM
tjc transport
i ain't rite
but there is about a 600 lb difference in the weight of a 5.4 and a 7.3 IDI.
our engines are close to 1200 lbs fully dressed, compared to the 600 or so lbs of the 5.4
Old Nov 19, 2014 | 05:31 PM
PB1976's Avatar
PB1976
Agreed..........but the warm oil is a sweet help
Old Nov 19, 2014 | 09:17 PM
ihateminimumwage's Avatar
ihateminimumwage
I checked mine with an IR thermometer, and shows close to 70 degrees, so after it's running for a bit you should be able to reach up and feel the heat.
You're lucky yours just stopped working; when my old one failed, I plugged it in and saw sparks and fire coming from it.
