What is wrong?!
Old Nov 16, 2014 | 06:05 PM
JWC 3's Avatar
JWC 3
Try to run it off a fresh can of known good fuel . Bypass the tank . Bottle feed it and see if it runs . Pull a plug if it will not start and see if it is flooded . Some plugs do not do well after being flooded . If you have good spark , good compression , at the proper time ... Fuel or Fuel Air Mixture is your problem .
Old Nov 16, 2014 | 06:07 PM
JWC 3's Avatar
JWC 3
Or a plugged exaust
Old Nov 16, 2014 | 09:03 PM
Charles2703's Avatar
Charles2703
I will definitely try to bottle feed it. That's a great idea! I'll check the exhaust the muffler is a little banger up but it lets out before the rear axle and is between the frame rails and it's lifted so it's pretty hard to get anything up in it but I will check it. Thanks for all the advice. I'll have an update soon hopefully. Any other advice would still be greatly appreciated
Old Nov 18, 2014 | 03:08 PM
1986F150six's Avatar
1986F150six
Originally Posted by Charles2703
It was running fine. Then I was pulling some bushes out for my neighbor and it just all of a sudden started running like crap. I thought it was the carb because I didn't mess with the timing at all. I tried my friends carb on it and it didn't help at all. So I figured maybe something happened with the timing so I tried to adjust the distributor and noticed that it wasn't getting better. So that's when I decided to try and reset the timing by finding top dead center. I find it by having my friend hold his finger over the hole until it blows out then put a dowel in the hole and turn it until the dowel stops moving up. I have done a compression test on the truck and all of my readings were good. I just don't know what could have happened.
Is it possible that something pulled on the fuel line? Check the rubber sections from the tank forward to the engine.
Old Nov 18, 2014 | 03:17 PM
Charles2703
I never saw any fuel leaking under the truck so hopefully that isn't the issue put I will check anyways.
Old Nov 19, 2014 | 10:41 AM
1986F150six
The fuel is drawn from the bottom of the tank, but exits out the top of the tank, so a line can be pulled loose and the gasoline stays in the tank, but the engine is then fed air.
chopped&dropped
Apr 23, 2009 06:27 PM
scottlane
Mar 14, 2009 11:34 PM
DarylZ
15
Sep 3, 2006 12:07 AM
armoredcar
1978 - 1996 Big Bronco
Apr 13, 2006 05:59 PM
77fromheaven
Apr 16, 2004 08:02 AM
