1964 Paint Color
Old Nov 11, 2014 | 08:45 PM
David1964's Avatar
David1964
1964 Paint Color
F10JD552144
114 VM F100 B81 A 12
5000 114 3600 647840
Can you tell by this tag number if this truck was just blue or was it 2 tone. 1964 F100. I think from what I heard it was 2 tone Blue and White although it looks like all the door jambs were Blue. Did they just paint the outside above the trim White and leave the inside of the jambs Blue. Thanks for any info. David
Old Nov 11, 2014 | 11:00 PM
SuperSabre's Avatar
SuperSabre
I'll give you pretty much a complete decode of your warranty plate information, and hope to answer some of your paint questions with some pictures. F10 = F100 2 wheel drive truck. J = 223 cubic inch 1 bbl I-6 engine. D = Dallas, TX assembly plant. 552144 = assembled in June, 1964. 114 = wheelbase in inches. VM = two tone exterior paint. V = Academy Blue. M = Wimbledon White. F100 = 5000 pound Gross Vehicle Weight rated half ton truck. B81 = blue interior upholstery (ND will have a better description). A = 3 speed light duty manual transmission. 12 = Ford 9 inch non-limited slip axle with 3.89 gears. 5000 = GVW rating. 114@3600 = NET horsepower rating and the rpm where achieved. 647840 = Domestic Special Order from the New Orleans district sales office. 64 = New Orleans. 7840 is the rest of the special order number, but all information as to what was special has been lost to history. Frequently it has to do with exterior paint, but when that happens, the exterior paint spot is usually left blank - not the case for you. So your guess is as good as anyone elses. As far as I know, if your paint scheme wasn't the special part, then it should look similar to the factory two tone paint on my '66 when I brought it home. Here are 3 pictures (one showing the door jamb) that may help you with your paint job. Good luck!
Old Nov 12, 2014 | 06:45 AM
David1964's Avatar
David1964
SuperSabre , Thanks so much , that clears up most of my problems, I was having issues with the doors and cab colors. Was the white in the bed rolled over about a inch down the flat piece inside the bed sorta like tailgate is. Thanks David
Old Nov 12, 2014 | 09:10 AM
SuperSabre's Avatar
SuperSabre
Yes it was. Picture attached. Good luck with your paint job.
David1964
Mar 8, 2015 05:26 PM
David1964
1961 - 1963 F100 Unibody
Nov 8, 2014 07:14 AM
mfnmxr
Feb 15, 2012 11:12 AM
daslugg
Jul 31, 2004 10:38 AM
fxrupr
Oct 25, 2000 11:09 PM
