Puddle under truck
Old Nov 10, 2014 | 10:13 AM
Padlock's Avatar
Padlock
Puddle under truck
I came outside and there was a puddle underneath my truck when I got where I was going. It was about 40 this morning so could that just be condensation? Or how can i tell if it's coolant??
Old Nov 10, 2014 | 10:49 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Maybe the puddle was already there?
Seriously, touch your finger to it, check color, consistency, and smell. Verify a leak by checking levels of fluid in the truck.
Old Nov 10, 2014 | 11:07 AM
Padlock's Avatar
Padlock
Well when my truck is hot the coolant level is at the tick mark and when it is cool it is less. Don't know why
Old Nov 10, 2014 | 11:43 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Passenger side? Running defrost?
Old Nov 10, 2014 | 12:06 PM
Padlock's Avatar
Padlock
No I didn't even run the heat at all since I had a jacket on.
Old Nov 10, 2014 | 12:20 PM
Padlock's Avatar
Padlock
No smell, no color when I wiped it on a white peice of paper but it felt slimey when I wiped it off my fingers. Any ideas?
Old Nov 10, 2014 | 02:30 PM
zhilton's Avatar
zhilton
Can you tell where it's coming from? Front, side or middle of the truck? It's possible it's condensation running off the truck, the seasons are changing.
Old Nov 10, 2014 | 03:40 PM
Rusty Axlerod
So, four possibilities
1. Condensate from the a/c. (If you use the defrost it runs the a/c to dry the air regardless of the temp you select)
2. Power steering fluid. Some brands have no or little color.
3. Coolant. A weak mix could look clear yet feel slimy.
4. Brake fluid. Clear (when it's fresh) and slimy feeling.
I suggest keeping a very close eye on the levels of the fluids, especially the brake fluid. If it's leaking enough to leave a puddle, the level will be dropping noticeably and very soon. If no levels are dropping after a week or so I'd relax and think it's condensate water from the a/c. And again, I'd double check that brake fluid level before driving it.
Kind of an afterthought, but diesel fuel could look clear in that situation but it smells pretty strong. I kinda skipped it but if you "smeller" doesn't work well that may be a possibility also. Check the brake fluid again .
MammaJammaTX
6.7L Power Stroke Diesel
18
Dec 25, 2016 10:30 AM
Montana300
Jan 27, 2014 09:29 AM
brdhouse6
Jun 29, 2011 01:24 PM
upnorthman
Jan 25, 2010 11:46 AM
XNrepair
Dec 8, 2007 08:58 AM
