ok here it goes
52967A-6661022NL
52967= serial number
A= GVW load rating
6= Ford 6 cylinder engine
66 Ford Integral Cab (Unibody)
10= F100
22= Wheelbase of the vehicle 122"
N= 1961
L= left hand drive
Trim 01= Vinyl and plaid woven plastic (Standard Cab)
1GG= Meadowvale Green Metallic (Medium)
3.89:1= axle ratio the us equivalent would be the axle code 12/Ford 9" Rear Axle
GVW= 5000 lbs
NP= 6 cylinder engine, NR would be a 8 Cylinder. Haven't seen anything yet on how they determined between 223 or 262. But most came with 223.
3.LD= transmission Ford 3 Speed light duty transmission.
You have a 1961 front grill, in '62 they went with Ford lettering above the grill.
Thanks Rob
That is exactly what I was looking for. Really appreciate it.
Now to figure out where I am going to start on the truck and go from there.
Greg
