Help identifying hose
Old Nov 9, 2014 | 07:25 PM
Javier89F150's Avatar
Javier89F150
So I recently got my first truck as a gift for my 20th birthday. A 1989 XLT Lariat F150. I've only driven it slightly because I have a cracked/dryrotted hose that connects from my valve cover to air filter box, and has white smoke coming out of it. And I have no idea what it's called! My dad mentioned something that it's my E.G.R..
And also every time I start my truck it has a weird idle, and the RPMs just keep jumping up and down, also when I sit at the light. I think it might be my fuel pump, now that I mention it,I also need to clean out my rear fuel tank.
So if anyone has any idea of what the hose could be, it'd be really appreciated! As well as what could be the source of the weird idle..
Old Nov 9, 2014 | 07:28 PM
Javier89F150
I have a picture, but I have boo idea how to post it via cell phone
Old Nov 9, 2014 | 07:35 PM
ncranchero's Avatar
ncranchero
Valve cover to the air cleaner box hose is the crankcase breather hose. Should have a filter for it to attach to inside the box.
Old Nov 9, 2014 | 07:45 PM
Javier89F150
I guess the only place to find it would be the local junk yard, fun!
Old Nov 9, 2014 | 07:55 PM
Bruners4's Avatar
Bruners4
The tube between the air box and the valve cover is part of the crankcase ventilation system. There is a PVC on the other valve cover that is part of this system. As to the tube, it can be replaced with a length of hose. Make sure to check the filter for it in the airbox.
Search this forum for "Check Codes" and see if your truck has any. This will help with the idle issue.
Old Nov 9, 2014 | 08:02 PM
Javier89F150
Appreciate all the help, come next weekend I should be working on my truck again to give feedback on how it goes
Nightshift life isn't truck maintenance friendly
Old Nov 10, 2014 | 09:19 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Any hardware or automotive store should have the same size oil resistant or fuel hose to replace that PCV hose with.
You dont want to run it like this, it is letting unfiltered air/dust/rocks/bugs into the engine crankcase.
pumpkinsf150
1997 - 2003 F150
May 18, 2016 09:01 PM
cmb2481
Jan 11, 2016 03:49 PM
Pollack Pete
Sep 23, 2012 12:09 PM
GasMonkey
General Automotive Discussion
15
Jan 29, 2005 11:22 PM
