What is coldest?
Old Jul 17, 2003 | 08:27 AM
jameslaz's Avatar
jameslaz
What is coldest?
Hi, Just me again, remember I am new to Exporers so I need a lot of help!!!
I would ike to know the best way to get my 97 Explorer cold fast. IS it best to have the rear air on or not. If its just me in it and I need to get it cold fast do the rear vents take away from the dash vents or do they have there own blower and all?
Thank you,
James AKA The New Guy
Old Jul 17, 2003 | 03:44 PM
Billy177's Avatar
Billy177
What is coldest?
i just drive with the ac and windows open for a few miniutes then roll em up and put them on maxac and max fan speed on frond and back
Old Jul 18, 2003 | 07:21 AM
bradcdavis00's Avatar
bradcdavis00
What is coldest?
I do the same as Billy. I roll down the windows to exhaust the hot air. In a few minutes I start the a/c, let the supply air chill, then roll the windows back up. My Explorer has one compressor so the refrigerant is being shared in the front and back. I just let them both run for equal cooling distribution.
Old Jul 19, 2003 | 04:02 PM
reberhardt's Avatar
reberhardt
What is coldest?
When it's just me in my Explorer and it's 115F+ here in Phoenix, mine feels the best when it is just the front A/C on and the rear is off. This is in my Sport, it would be even more pronounced in a 4-door. Once it gets really hot like it does here, the sun will heat up the entire inside about as quickly as the A/C can cool it off. When you turn on the rear, it takes away some of the cooling from the front. To me it's more comfortable having the fronts on to a level that I am comfortable. I don't concern myself with how hot it is in the back unless someone is riding back there. I can turn my fan 1 speed setting lower for the same comfort level if the rear is off.
When stopping and turning everything off, within 3 or 4 minutes it is uncomfortable enough inside to make you want to get out. When I get back in, I turn the A/C on "norm" to get the compressor going and the air moving in the vents. After 2 or 3 minutes I turn the fan to "high" and then may turn the A/C to "max" depending on how hot it is outside.
roostercrows
1978 - 1996 Big Bronco
Nov 13, 2007 08:52 AM
JamesSandberg
1983 - 2012 Ranger & B-Series
Aug 18, 2006 04:57 PM
scooter1986
Feb 14, 2006 12:23 AM
jjasiole
Bronco II
Oct 15, 2004 12:40 PM
hirschi
Jun 30, 2002 01:51 PM
