New tires
Old Nov 8, 2014 | 06:34 PM
Powerstoke73's Avatar
Powerstoke73
New tires
What PSI should i run i would like to make these tires last as long as possible i just purchased 6 brand new 235/85/16s LTs and i was wondering how much PSI to keep in them just riding around empty without pulling or hauling anything
Side walls says 80 max psi
Old Nov 8, 2014 | 07:46 PM
cj45lc's Avatar
cj45lc
I run 75 rear 55 front, rotate them @10,000 miles
that's a 2wd & I got a little over 75,000 miles out of my last set
Old Nov 8, 2014 | 08:02 PM
glockholiday's Avatar
glockholiday
I run 75 up front and 50 in the rear, empty. I bump the rears up to 65 when towing my 35' toyhauler.
Even the 50 in the rear is too much for the empty dually and it wears the center of the tread first but it's not too bad.
And I only rotate left to right, I'm not busting them off the wheels to rotate the duals to the front.
Old Nov 8, 2014 | 08:23 PM
Powerstoke73
Okay cool so 50 in the rears and 75 in the front and i should get some good miles out of them
Old Nov 8, 2014 | 08:55 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
75 up front will shake your teeth loose. 2WD or 4WD? Empty I run 55 all around on OE size Bridgestones, wears pretty flat.
Old Nov 8, 2014 | 10:09 PM
glockholiday
Anything under 65psi in my fronts it quickly starts to wear the inside and outside edges of the tires like they're under inflated or overloaded, and since I can't put the 7.3 on a diet I just bump up the pressure.
And don't forget guys, he said 6 tires so we're talking about a dually here.
Old Nov 9, 2014 | 04:56 AM
Tugly's Avatar
Tugly
I've never been able to run lower than 65 PSI in the front without bulging - and crazy wear. Stinky is 4WD, though.
Draw chalk across the face of the tire and drive a short distance. Too much air rubs the center off, too little rubs the outer edges off. Shoot for even chalk wear.
Old Nov 9, 2014 | 09:02 PM
sgarder's Avatar
sgarder
X2 on the chalk line Tugly. This is your best way.
Old Nov 9, 2014 | 09:34 PM
jhl3's Avatar
jhl3
X3 on the chalk. Depending on seasonal temps 72-76 on the front and 48-54 on the DRW. Otherwise, like they are saying, if any lower on the fronts they will wear prematurely on the edges and any higher on the rears, they will wear in the center. Got 82k on the last LTX MS2's. If you are hauling heavy you may need to bump the rear up 10-15lbs or so. It is a pain if they do not align the valves to the holes when they change the tires.
Old Nov 10, 2014 | 07:35 AM
Powerstoke73
Okay great thanks alot fellas I appreciate all the help
trucks rides better already
Old Nov 30, 2014 | 09:07 PM
Mystic_Cobra's Avatar
Mystic_Cobra
Question
Can the front tires/wheels be rotated (front to rear criss-cross) to the outers on the back of my dually?
My 2015 Platinum has steel on the rear insides and aluminum on the other four.
Old Dec 1, 2014 | 03:38 AM
glockholiday
I don't think they are the same wheel. Even if they would swap they would look like hell, there's no cleaning the inside of my wheels, 14 years of road grime.
Old Dec 1, 2014 | 03:57 AM
jhl3's Avatar
jhl3
I don't believe they can be without dismounting the tires. I have a similar issue. If you have one in your area, Discount Tire does the rotation for no extra charge most of the time. Additionally, since they want your future business, they do this even if your tires were not purchased from them originally.
Old Dec 1, 2014 | 04:31 AM
glockholiday
I purchased my tires from them and they said they'd dismount and rotate for free. But I don't do it, I just rotate side to side.
Old Dec 1, 2014 | 12:12 PM
Mystic_Cobra
Mine is a 2015, so the aluminum wheels probably aren't black on the inside yet. If the only reason not to rotate is because the aluminum isn't polished on the inside, then I don't care about that. I'll run them backwards in the winter when they are covered with road grime. As long as they are the same color (swap fronts with outside rears) I won't care. I don't have any rear hub caps (since they keep falling off)...so how much worse can it be?
traveldawg
May 23, 2019 11:54 PM
hernC
All Things Towing
Apr 24, 2018 08:12 PM
Franko72
27
Mar 5, 2011 12:30 AM
PERFORMANCE RED
Jun 13, 2009 08:20 AM
eric777
Dec 18, 2006 12:51 PM
