Horn Ring Springs
Old Nov 8, 2014 | 10:14 AM
gangstakr's Avatar
gangstakr
Horn Ring Springs
I've noticed that the springs are different sizes. Most common are the 2" or miked at 1.96 The other one is "1.75
Where can I find the ones that are 1.75?
What's the part number for the 1.75" spring?
Old Nov 8, 2014 | 10:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C0DF-13A807-B .. Horn Button Spring / Reproduced
1961/65 F100/250 2WD - 1966 F100 4WD - 1967/70 F100/350 / 1960/64 Falcon/Comet - 1962/64 Fairlane - 1963/64 Custom/Custom 500 - 1966/74 Bronco.
C0DZ-13A807-B .. Horn Ring Spring / Reproduced
1961/65 F100/250 2WD - 1966 F100 4WD - 1967/70 F100/350 / 1960/64 Falcon/Comet - 1962/64 Fairlane - 1963/64 Galaxie 500/500XL - 1965 Mustang w/a generator - 1966/74 Bronco.
C1TZ-13A807-A .. Horn Ring Spring / Obsolete
1961/65 F100/250 4WD - 1961/66 F350 Custom Cab - 1966 F250 4WD // 1961/74 Econoline.
C1TZ-13A807-B .. Horn Button Spring / Obsolete
1961/65 F100/250 4WD - 1961/66 F350 Standard Cab - 1961/66 F500/1100 - 1961/74 Econoline - 1966 F250 4WD
Old Nov 8, 2014 | 11:25 AM
gangstakr's Avatar
gangstakr
So are all the ones you listed part numbers for 1.75"?
Old Nov 8, 2014 | 11:30 AM
NumberDummy
I haven't the slightest idea what their diameters are, as the car/truck parts catalogs don't list this info.
C3DZ-13A805-D .. Horn Ring / Reproduced
1960/63 Falcon/Comet - 1961/65 F100/250 2WD - 1966 F100 4WD - 1967/70 F100/350.
What most people are unaware of...there is a rubber horn blowing pad (CODZ-13A813-A) inside this ring. When it flattens out and/or disintegrates, the horn will no longer blow.
Old Nov 8, 2014 | 06:47 PM
gangstakr's Avatar
gangstakr
Ok N.D. one last spring part number.
What about the four spoke steering wheel with four spoke horn ring. Do you have a part number for that spring?
When did the four spoke steering become available?
Old Nov 9, 2014 | 06:00 PM
gangstakr's Avatar
gangstakr
Bumping, looking for answer regarding horn spring for the four spoke horn ring.
This would be on the four spoke steering wheel.
Old Nov 10, 2014 | 10:25 AM
NumberDummy
4 spoke steering wheel springs, also used on Econolines.
1tonner
17
Mar 8, 2016 10:16 PM
ajbremer
Feb 4, 2015 10:18 AM
centralNH
Mar 17, 2014 08:51 PM
xstrange
Dec 30, 2009 05:43 PM
joe cowan
25
Dec 24, 2009 10:13 AM
