Dumb Question??
Old Nov 6, 2014 | 03:18 PM
hydro man 17's Avatar
hydro man 17
Dumb Question??
I just discovered that one of my ESOF hubs was in the locked position. I personally have never used them in manual so I don't know how long it has been that way. I don't drive it that much so I don't know if some kid messed with it in a parking lot or what.
Questions,
1. Will this harm anything other than un-necessary wear?
2. Could this be the / a cause for the truck to wander down the road? Won't have a chance to drive it 'till tomorrow.
Thanks,
Mike
Old Nov 6, 2014 | 03:28 PM
redbayredneck's Avatar
redbayredneck
Shouldn't cause any issues other than unnecessary wear,
I don't know why it would cause wandering down the road, but it might, I'm not sure.
Old Nov 6, 2014 | 10:16 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
If it were to cause issues, GM and Dodge would have been doing billions of dollars worth of warranty repairs due to one side being driven all the time (by the freely-rotating wheel) and the other one doing nothing but rotating backwards with no load on it.
Comparing "3/4 Ton" and "1 Ton" trucks here, GM still disconnects the right front axle shaft leaving the left front to drive the side and spider gears all the time. They have done this since 1987 starting with the half tons (the S10/15 trucks have had it since 1983). Dodge, up until 2002 did essentially the same thing (albeit with a superior solid-axle monobeam design) and now just leaves it all connected all the time for some reason.
Old Nov 6, 2014 | 11:02 PM
hydro man 17
Thanks for the replies, I will sleep a little easier tonight.
Old Nov 8, 2014 | 04:12 AM
Kamstutz's Avatar
Kamstutz
Your needle bearing inside the hub would be used because of the shaft turning, but should not have caused any damage. When is the last time your needle bearings were lubed? I run my 4X4 every so often to keep everything used and lubed.
Old Nov 8, 2014 | 11:55 AM
hydro man 17
I had a lot of recent (mileage wise) work on the front end. Virtually everything was redone when all was said and done. I was thinking last night that a slight vibration that I have felt recently (via the drivers side floor board) would probably be the front drive shaft spinning and driving the the internals of the transfer case. I intend to do a shot drive today to confirm one way or the other now that BOTH hubs are unlocked!
Old Nov 8, 2014 | 03:04 PM
jhl3's Avatar
jhl3
Hi, I had the same issue with my ESOF due to a vacuum leak. The right side would disengage and the drivers side would not. It did cause a slight vibration/roar that was just noticeable enough to make you wonder if it was the beginning of a bearing going bad. The auto lockers are easy to pull with only needle nose pliers. Then you can clean the inside of them to see if that helps. Mine had a very fine dust in them that would cause them to not unlock.
Edit: and yes, when one side is not unlocking it creates a bit of resistance on that side and you can feel it in the steering wheel and notice it favors one direction a little more than the other...
Old Nov 9, 2014 | 11:50 AM
hydro man 17
jhl3
My issue was not that the ESOF did not disengage, it was that one side was locked in manual and the other was in auto. Anyway took it for a run yesterday and and there is some slight improvement in the feel on the road but still have a slight vibration that I think is exhaust related, like maybe the rubber is missing from a hanger or something.
Patrick R.
General Automotive Discussion
Sep 19, 2015 12:23 PM
Tugly
Nov 29, 2014 10:32 AM
aquaman
33
Dec 23, 2005 10:17 AM
huntercgr
Jun 5, 2004 09:15 AM
