Hello everyone, I bought a 1977 f150 ranger and I want to put 35-38.5" tires under her. This is my first one and I don't know what lift to put on it, so if you professionals could help me out I'd really appreciate it, thanks
and depending on the rear axle they should be done also for 38's
You will also need to consider the gear ratio of the differentials .. You could make the truck undriveable with your current gear ratio and motor with 38's .. All these things have to be considered before you lay down the cash for those tires ..
Where can I get bigger gears? I know it's a dumb question but here it goes, do I just have to replace just the old gears to get bigger gears? Or is there more to it than that?
I don't know how much hp it has??? But it has the stock 351/400m, and I at least wanted 6" lift 😎, but I wanna use it 4 transportation and mud now and then
