bigger gas tank
Old Apr 11, 2002 | 02:23 PM
95flareside's Avatar
95flareside
bigger gas tank
anyone replace there gas tank with a bigger one. i have a 95 f150 4x4 5.0L- only has one tank- seems like i'm always filling it up. i'd like to drop in a larger engine, but i can barely pass a gas station as it is. i'd also like to last abit longer at our local mud pit before having to refuel. thanks for any help.
Old Apr 11, 2002 | 09:18 PM
orange peel's Avatar
orange peel
bigger gas tank
i find it hard that you need to fill up that often. my truck has 2 gas tanks but only one works and i hardly have to fill it up. what im doin is replacing my gas tanks with fuel cells to put in the bed so i wont have to worry about smashing a gas tank on a rock.
Old Apr 12, 2002 | 08:10 AM
95flareside
bigger gas tank
i'm going to swap to 4.10 gears in about two months, how bad will that affect it and will 4.10 gears handle 35 x 12.50' s. i think i have a 8.8" rear end, is it worth upgrading to a 9". i'm new at this so i appreciate your imput.
Old Apr 12, 2002 | 11:12 AM
markus's Avatar
markus
bigger gas tank
I've heard that you an remove the spare and stick a Bronco gas tank in there. I've never tried it so I would do a little research before going out and buying and tanks.
Markus
Old Apr 12, 2002 | 03:58 PM
95flareside
bigger gas tank
thanks marcus, i figured something would fit.i planned on mounting my spare in the bed.
Old Apr 12, 2002 | 06:33 PM
ddestruel's Avatar
ddestruel
bigger gas tank
You can put a bronco tank in place of a rear tank, you loose your spare tire mount but oh well. make sure the tank's pump is good all other things marry up, except some later model trucks use a four pin circular plug and pig tail vs the earlier four pin tank plug, minor set back a little wiring can fix get a pig tail and or plug with the pump to make sure you dont have to run back. Use your existing brackets, measure and bend to fit then get a little more metal it will take i think about 10 more inches a few bends to tuck the tank in tightly. Your fuel lines will slide in with a little bit of finess and squeezing so you can see what you are doing. Think that is about all there is to it. I had mine done in about 2 hours.
Hope that helps
Dusty
Why Buy new when you can build and tailor it cheaper?
F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel w/ NV4500 5spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, Converted to Sterling 10.5 gears w/3.73 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front, 33's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear.
Old Apr 12, 2002 | 08:58 PM
95flareside
bigger gas tank
cool, thanks dusty- can a 33 gallon bronco tank fit?
Old Apr 12, 2002 | 09:42 PM
ddestruel's Avatar
ddestruel
bigger gas tank
I put one in my 96 ext cab short bed, and it fit without any pounding. its the same width as your rear frame rails, sits lower and is shorter length wise than your old tank. roughly about 8" lower. Does your truck use a rear mount tank or a front frame rail tank though? better check on that before doing any thing too extensive.
Old Apr 12, 2002 | 10:52 PM
PAUL_2's Avatar
PAUL_2
bigger gas tank
rdinmv
Feb 21, 2014 03:38 PM
Dogmann
Jan 28, 2014 07:38 AM
4EyedTurd
Dec 20, 2012 11:49 PM
Towmanjbo
Jun 9, 2007 03:56 PM
