lubriguard
Old Nov 5, 2014 | 09:06 AM
jmtbiggin's Avatar
jmtbiggin
lubriguard
Their 15w40 is cj4,does it have any business in a 6.0? Reason I ask is it very economical.Thanks
Old Nov 5, 2014 | 09:39 AM
mhoefer's Avatar
mhoefer
I am not familiar with the the brand, who is it sold by? If it I is rated API CJ4 yes, if it is "equivalent" to or similar to, then I would wonder.
Old Nov 5, 2014 | 12:06 PM
69cj's Avatar
69cj
Lubriguard 15W-40 CJ-4/SM Engine Oil –
CJ-4 represents the highest level of engine
protection and performance ever built into a new lubricant specification. It was designed
for all diesel engine applications, including today’s emission controlled engines with
EGR and diesel particulate filters using Ultra-Low Sulfur Diesel fuel (<15 PPM Sulfur)
(ULSD) and Low Sulfur Diesel (LSD). It is formulated to provide improved wear
protection, deposit and oil consumption control, soot-related viscosity control, prevention
of viscosity loss from shearing, used oil low-temperature pumpability and protection
from thermal and oxidative breakdown. It also contains a sophisticated additive system
that is specifically designed to improve the protection of advanced emission control
systems such as diesel particulate filters.
It is suitable for use in almost all foreign and domestic diesel engines for both the latest
2007 emission compliant and older engines. Always consult your owner’s manual for
proper application.
meets API Service Classification CJ-4, CI-4
PLUS, CI-4, CH-4, CG-4, CF-4, CF/SM, SL, SJ, SH. It has received OEM Approvals for
Mack EO-O Premium Plus, Volvo VDS-4, DDC Power Guard Oil Specification 93K218,
Cummins CES 20081, Renault RLD-3, ACEA E7. It is recommended for Caterpillar
ECF-1a, ECF-2, ECF-3, Mack EO-N Premium Plus 03, Mack EO-N Premium Plus, EOM
Plus, EO-M, Mercedes Benz 228.31, MAN 3275, DDC/MTU Series 2000/4000
category 1 and 2 engine performance, Cummins CES 20077, 20076, Volvo VDS-3,
DHD-1, ACEA E7-04 E5 and E3, JASO DH-2.
Benefits
Handles double the soot of API CI-4 oils
Protects emission control systems
Outstanding oxidation stability
Excellent low temperature properties helps speed cold starts
Universal product for mixed fleet operations
High 10 TBN
The thread didn't state who retails it.
Old Nov 5, 2014 | 12:08 PM
69cj's Avatar
69cj
Typical Characteristics
Lubriguard 15W-40 CJ-4/SM 15W-40
API CJ-4, CI-4 PLUS, CH-4, CG-4, CF-4, CF/SM,
SL, SJ, SH
X
Caterpillar ECF-1a, ECF-2, ECF-3 X
Cummins CES 20081, 20077, 20076 X
Mack EO-O Premium Plus, Mack EO-N Premium
Plus 03, EO-N Premium Plus, EO-M Plus, EO-M X
Mercedes Benz 228.31 X
MAN 3275 X
DHD-1, ACEA E7-05, E7 and E5 X
Volvo VDS-4, VDS-3 X
DDC Power Guard 93 K218 X
DDC/MTU Series 2000/4000 1 and 2 engine
performance
X
Allison C-4 X
Global DHD-1 X
JASO DH-2 X
Renault RLD-3 X
Product Data Test
Method
Typical
@ 40° C, cST D445 120.0
@ 100°C, cST D445 15.7
Viscosity Index D2270 138
Pour Point °C (°F) D97 -36 (-33)
Flash Point °C (°F) D92 238 (460)
Neutralization No., TBN-E D2896 10
Sulfated Ash, wt.% D874 1.0
Cold Crank Simulator, cP D5293 6620/-20°C
Mini-Rotary Viscometer TP1, cP D4684 23700/-25°C
High Temperature High Shear, HTHS @150°C, cP D4683 4.3
trippn4re
23
Jun 2, 2014 04:16 PM
pawpaw
Oil & Lubrication
Apr 12, 2014 09:37 PM
Karl Aube
General Diesel Discussion
17
May 7, 2009 02:35 PM
mbingham99
Apr 25, 2009 11:01 AM
partsman01
Aug 27, 2008 02:14 PM
