As far as I'm concerned the truck is a 1967 Ford F100 4x4 with a 352. I'm guessing this is how it came from the factory. Not sure how I can go about decoding all the numbers. I looked up a decoder online but was given wrong information. (Saying the truck is a 1976 F100 with a 360.)
Either way, any information is much appreciated.
F11...... F100 4wd
Y....... 352
R....... built in San Jose, CA
B40355........ Made Jun 67, 40355 consecutive serial number
131....... wheelbase
U........ lunar green
F110........ F100 4wd
L81........ Standard cab with custom cushion - Med. Green Woven Plastic and Crush Vinyl
A......... 4spd np435
08........ 3.50 rear gear
5600....... gvw
172......... hp
4000....... rpm
7311798........ ordered from Salt lake city(code 73), the remaining is the order number
F11...... F100 4wd
Y....... 352
5600....... gvw
172......... hp
4000....... rpm
Wow, didn't realize how much information you could get from the door code. Awesome information, thanks!
VIN: F11YRB40355 / WB: 131 / COLOR: U / MODEL: F110 / BODY: L81 / TRANS: A / AXLE: 08 / MAX GVW LBS: 5600 / CERT NET HP: 172 / RPM: 4000 / DSO: 7311798
F11 = F100 4WD
Y = 352 2V
R = San Jose CA Assembly Plant.
B40355 = 1967, assembled June 1967.
131" Wheelbase.
U = Lunar Green.
F110 = F100 4WD, 5,600 lbs. GVWR
L81:L = Medium Green Petticrush Vinyl & Medium Green Leeds PatternWoven Plastic / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,600 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
7311798:
73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from.
11798 = Domestic Special Order number, this truck was not "bought off the lot."
Per the original purchasers order, FoMoCo sent the truck out after it left the assembly line to have special equipment installed that would not have been an RPO (Regular Production Order).
Could have been some type of "back of cab" equipment like a Utility Bed, or a step front bumper w/a winch installed, or?
Since martiauto.com has all the original FoMoCo records for 1967/79 vehicles, you could contact him with the VIN and ask for a copy of its original build sheet. Marti charges a fee for this service.
I have a '67 mercury m250 and my DSO is A68482 I was wondering if anyone could tell me where the A6 is I've been searching for hours online and can't find it any info at all. Possibly Alberta?? As far as I know that's where the truck is from.
F11...... F100 4wd
Y....... 352
5600....... gvw
172......... hp
4000....... rpm
Ford Motor Co. of Canada Ltd.
A6 = Western (Ford) District Sales Office, where the original selling dealer ordered the truck from.
8482 = Domestic Special Order number. Truck was ordered special by the original purchaser, not "bought off the lot."
Scroll down to District Codes, then look at column right.
