Parts for blown engine
Old Nov 3, 2014 | 01:06 PM
power-power's Avatar
power-power
Hi all
I have a 97 Explorer 4.0 with blown engine. Any source for parts other than Ebay appreciated. I don't want to go Ebay because of quality concerns but as a last chance. I need timing kit, rods, valves etc.
Thanks
Old Nov 3, 2014 | 01:42 PM
Alex from GA's Avatar
Alex from GA
Try rockauto.com. They usually have the best prices. You might also try amazon.com.
Old Nov 3, 2014 | 10:48 PM
Mikeman's Avatar
Mikeman
For the two engines I've done (quite a while ago), I let the automotive machine shop provide parts. The main reason for this is because they will be doing the measurements and will know what size of pistons and bearings you'll need. For example, you may need to go .020 over on the pistons, but the mains might just need a polish and the rods might need to be .010 under. Lots of opportunities for you to screw up. These guys are gearheads and know what works. Ask what parts they recommend and let them know you're willing to spend a few extra bucks for quality parts if you think something better is available.
Old Nov 3, 2014 | 11:55 PM
85e150's Avatar
85e150
Is this a 4.0 SOHC?
If so, those engines are interchangable year to year, even '05 and up Mustangs. You need to swap over your manifolding etc, and all the electronics, but they do interchange.
Rather than rebuild one, consider a later model swap.
Serving suggestion.
If you are interested, I will dig up the links to the story on this.
jpwade1
Aug 19, 2014 09:11 PM
mudguts
Nov 5, 2012 08:00 PM
ftrk66
Mar 20, 2012 12:16 PM
ford2go
Garage & Workshop
Jan 10, 2012 10:01 PM
teardropty
13
Nov 25, 2011 03:05 PM
