flywheel?
Old Nov 2, 2014 | 10:14 PM
Bluethunder3320's Avatar
Bluethunder3320
flywheel?
i have a 78 f150 400 i am swapping a np435 in place of the old c6. i got a trans that used to be behind a 351m.
i bought a flywheel from someone who said it came from a 400 but he says the 351m is the same and uses a 12" clutch as well which is not what ive found. i have a feeling he didnt know what he had/what hes talking about.
D7TE 6380 DC is what it says on the back. there are 4 large threaded holes and 8 smaller ones farther out and i cant tell if they are threaded. the measurement is about 12 1/2" between the 4 larger holes.
if it is a 351m flywheel i will buy an 11" clutch, if it is a 400 then i will buy a 12" clutch, thanks any help is appreciated!
Old Nov 3, 2014 | 07:46 AM
redroad's Avatar
redroad
The flywheel should be 180 tooth and flat and clutch 12" for the 400 ..
Old Nov 3, 2014 | 02:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ID number: D7TE-6380-CE = Ford part number: D7TZ-6375-D .. 400 Flywheel-Use with 12" clutch / (6) 5/16" -18 pressure plate attaching holes on a 12 7/8" bolt circle.
ID number: D7TE-6380-DE = Ford part number: D7TZ-6375-E .. 351M Flywheel-Use with 11" clutch / (6) 5/16" -18 pressure plate attaching hoiles an a 12 3/8" bolt circle.
hail destroyer
Jul 1, 2019 09:25 AM
Lad1175
May 14, 2018 09:33 AM
squarethumps
WTB - Parts & other
Oct 14, 2013 11:14 AM
hairyboxnoogle
Nov 26, 2012 09:44 AM
