swap
Old Nov 1, 2014 | 04:10 AM
Fireman_dave's Avatar
Fireman_dave
swap
I am not sure if this is the right place for this post but i will give it a shot....i have a 1990 f350 currently with a 1993 idiT, it is getting tired with over 400k, i am thinking of swapping in a T444E, from what i can tell it is very similar to a powerstroke but all the electronic modules appear to be mounted to the passenger side valve cover, i understand some things like oil pan will have to be changed, however i am concerned about the electronics in a non electronic vehicle, has anyone done this swap, how feasible is it...ect
Old Nov 1, 2014 | 08:29 PM
tecgod13's Avatar
tecgod13
You'd have better luck getting information from the next forum up, the 7.3 Powerstroke forum.
The guys here would rather get rid of a Powerstroke and swap in the IDI engine you already have!
That being said, yes its feasible. The best (easiest/cheapest) would probably be to find a wrecked donor vehicle with good engine. That way you'd have access to the whole wiring harness, all the electronics and the engine with all accessories and what not.
If you use the 7.3 Powerstroke your transmission should bolt up no problem. I'm not sure why the oil pan would have to be changed though. Seeing that in '94 you could get either the IDI, IDI turbo or Powerstroke straight from Ford I'd have to imagine that the engine would drop into place with minimal differences, possibly different motor mounts on the frame. But honesty I'm just guessing as far as that goes.
One thing that might be a hiccup, is getting stuff on your dash to interface well. If I read your post right, you have a 1990, which is the older dash with mechanical speedo. That shouldn't be a problem, as it would still drive off your transmission (or transfer case if 4x4). But I don't know how easy it would be to get the rest of the bells and whistles working. Might take some careful wire tracing and splicing as the harnesses wouldn't match up like a 92+ truck with the electronic speedo and same generation dash as the 7.3 Powerstroke trucks.
Galaxie mike
Apr 11, 2016 09:24 PM
Fireman_dave
13
Dec 17, 2014 12:58 PM
DarylZ
40
Aug 23, 2010 05:58 AM
chevma-67
Sep 28, 2008 05:28 PM
Black Cowboy
Feb 11, 2008 06:04 PM
