Stiction Additive
Old Oct 31, 2014 | 05:14 PM
granny_rocket's Avatar
granny_rocket
Stiction Additive
Hi Folks,
I know this is a fairly common topic but I wanted to hear some opinions on using Hot Shot's stiction eliminator. From what I've gathered so far it's another snake oil but in some cases works well.
My truck has 177,777.7 miles on the clock (it just hit that number this morning...lucky numbers eh?). Over the last few months it's been sitting. Prior to that it really hadn't been run all the much but when I did run it, I ran it. I switched to synthetic oil many miles ago (not overly relevant but just fyi).
Over the years I've watched my fuel mileage go down. I haven't yet been able to determine if it's a stuck fuel selector valve pushing return fuel into the un-selected tank (then leaking out as the un-used tank isn't used because it has a hole in it).... or why the mileage went down but it went down.
Anyway, to make a long story short here, I've noticed the engine doesn't seem to idle as smooth as it once did. After reading about the stiction additive/eliminator I was thinking this might help kind of clean some crap out.
So what are your thoughts on it? I bought the $50 bottle but haven't opened it yet. If I get a lot of negative input I'll simply bring it back. Otherwise I don't mind making the investment...
Thanks Much,
Old Oct 31, 2014 | 05:20 PM
fordman67's Avatar
fordman67
I think its a rip off honestly.my brother in law tried it.I don't think it did anything ground braking.
Heck I have 331000 on original injectors.if you keep the oil changed that's most important.I don't use any fuel treatment it anything. Mine runs just fine as of now.
Maybe it would be your cure all but I'm not buying it...
Old Nov 3, 2014 | 07:43 AM
BoKnowsDiesel's Avatar
BoKnowsDiesel
Former Vendor
If it is a stiction problem, the Stiction Eliminator will clear it out. We have had many customers with 7.3's who have had a lot of luck and have seen major differences. Go ahead and try the product. If you are not happy with it, let me know, and I can get a full refund out to ya.
Old Nov 3, 2014 | 10:00 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
"Stiction" is a term created for the spool valve issues the 6.0 injectors (possibly some other injectors in the industry) have, but is not a problem with 7.3 injectors.
The 7.3 has Poppet valve wear issues that, although a product like Hot Shot might help it run better, it's not a "Stiction" issue that the product will help cure. If Hot Shot helps your 7.3 truck run smoother, then that's proof that you have injector issues that can only be remedied by an injector rebuild.
If a 6.0 starts better and runs smoother with the use of Hot Shot, RevX, etc, then those products are helping to remove the 'varnish' that accumulates on the Spool valve and may actually help 'fix' those injectors. They have a positive effect on some 6.0's and do nothing on others. It all depends on the severity of the accumulation of the 'varnish'.
I wish people would understand the difference and use the term "Stiction" properly.
Thank you.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Nov 3, 2014 | 10:21 AM
BoKnowsDiesel
Former Vendor
Anywhere that you have high pressure and high heat, you will get a stiction buildup. Any HEUI injector will have stiction in it. Yes, the 7.3 was not prone to classic case of stiction that the 6.0 was prone to, if the poppet valve is worn, it's just plain worn. It is still helpful to give the injectors a good flush every once in a while. Most of the time, there is still a noticeable difference in the 7.3. Check out how another user tried the product in his truck... Hot Shot Secret- A viability review for restoring functionality to high mileage 7.3 injectors
Old Nov 4, 2014 | 02:45 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Well, I disagree 100%.
There simply is no "Stiction" issue with 7.3 injectors.
We will have to agree to disagree on this.
__________________
burnhedge
16
May 28, 2019 12:06 PM
guthrie&co
Feb 9, 2011 01:23 AM
RobertJohn
Mar 12, 2010 08:46 PM
skeeterguy34
Jan 7, 2010 05:30 PM
coop25
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 28, 2009 01:04 PM
