Want to run 4.6 from crown vic. What do I need from donor car as far as electric?
Old 10-29-2014, 09:01 PM
old_blue1's Avatar
old_blue1
old_blue1 is offline
I have a donor car and will be using front and rear suspension. i have engine and trans too that I want to use. I have heard the trans wiring is part of the body harness. I am looking to find out how much wiring I am going to
need from the car. Do I need any of the dash harness? How much of the body wiring will I need?
I am not going to use any of the gauges or anything so just looking to get enough to use trans and engine.
Thanks.
Old 10-29-2014, 09:38 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
I would suggest you go here: https://www.ford-trucks.com/forums/1...0-project.html and do some reading, he is doing almost the same as you are talking about..
Old 11-18-2014, 06:25 PM
ModularFairlane's Avatar
ModularFairlane
ModularFairlane is offline
What year is your donor car and what is the recipient? I use these cars for donors myself and find that the '98-'01 P-71 police interceptors are the easiest to work with. There is no PATS on these vehicles, and a lot of them don't have ABS.
Old 11-18-2014, 10:17 PM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
In some cases it is easiest to disconnect the entire harness and all of the modules then remove what you don't need or want later on. One tip I have is to remove everything and either plug it in or label EACH connector that you unplug with masking tape and a marker or something to that extent. You can pull each section of harness out and "de-pin" the connectors at the modules assuming they don't need that sensor for input/output.
It depends on how much you want to carry over, do you want the BCM to control the dome lights (not sure if that's how the car is wired or if its a simple circuit) but you get my drift.
For most computer controlled cars you will need the Instrument cluster (some PCMs require the odometer to run) Ignition with the proper keys, the harness obviously, shifter and trans harness. If there is any PATS (passive anti-theft) you will need the BCM or anti-theft module to avoid starter immobilization.
Old 11-19-2014, 09:20 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Contact Chuck if you only want the harness to run your engine/transmission. He'll custom build one for exactly what you want.
Chuck Field
Chuck's Roadster Electrics
12438 Hillcrest Drive
Nevada City CA 95959
530-477-7829 phone
Tell him BJ sent ya probably won't do any good but Ya never know
Tony79f100
Modular V8 (4.6L, 5.4L)
09-29-2016 12:08 PM
Tony79f100
09-16-2016 10:11 PM
bigfoot7180
09-03-2012 10:33 AM
Rokcrln
07-04-2009 10:36 AM
RUSTY50F1
19
11-22-2006 12:20 PM
Quick Reply: Want to run 4.6 from crown vic. What do I need from donor car as far as electric?
