first pic after 3 window sections removed by students. working on where to place rear axle. plans are for a 2 link and bags. rear body section will line up better in a factory seam once rear axle is moved foward
Reason: spelling
Will make the chop decision after we get it all back togeather.
It does look like a chop would help the profile.
May look better when the windows are installed
May not use the straight axle, looking at replacing with a front section from a p30 box van, same frame deminsions plus disc brakes ane power steering, also dropped spindles and springs are avalible
