4x4 question
Old Oct 28, 2014 | 10:17 PM
guyina4x4's Avatar
guyina4x4
4x4 question
I just bought 2003 expedition
While driving when I switch from 2 hi to A4wd I hear a noise, no grinding just a thwuuUMP, seems a little to loud but I don't know.
I checked the Iwe system today and it seems to be working properly, holds steady vacuum
Is any noise normal? Or should it be silent?
Old Oct 28, 2014 | 11:23 PM
alloro's Avatar
alloro
No it shouldn't be noisy. You might just have worn u-joints on the front drive shaft. During the initial engagement you're likely hearing the slack being taken up.
Old Oct 29, 2014 | 12:30 AM
guyina4x4's Avatar
guyina4x4
I like that answer, I'll check the front dive shaft
Thank you
Old Oct 30, 2014 | 06:56 AM
meborder's Avatar
meborder
mine makes the exact same noise when you switch into a4wd.
owner's manual says it is normal.
should just be a quick noise like you describe as the front driveline comes up to speed. as the IFWE (hubs) engage at speed the front drive line quickly goes from zero to whatever speed you are traveling.
owners manual says you can do that up to 65mph, and i have, but it is a little unnerving. the slower you go when you make the switch, the quieter it is.
i haven't checked the front driveshaft for play, but it is completely silent once engaged, so i haven't been overly concerned.
IME, and FWIW anyway.
Old Oct 30, 2014 | 07:34 PM
guyina4x4's Avatar
guyina4x4
see I wondered about that, I don't know how it could engage totally silent at speed.
I checked my front drive shaft and the U joints are fine.
I don't have any other noise either, just when engaging at speed.
so I'm not going to worry about it either.
thanks guys
BAD RONALD
Aug 28, 2018 10:45 AM
09f250v10
6.7L Power Stroke Diesel
Aug 22, 2016 06:51 PM
efizzle
Aug 9, 2009 08:10 PM
Frumious
1983 - 2012 Ranger & B-Series
Feb 13, 2008 11:05 PM
ThomL
1978 - 1996 Big Bronco
Jan 22, 2004 09:38 AM
