changing brakes
Old Jul 16, 2003 | 06:20 PM
zoocrew624's Avatar
zoocrew624
changing brakes
This is probably a dumb question but how do I remove the caliper on my 91 explorer so I can change the brake pads...help me out please
Old Jul 16, 2003 | 07:24 PM
Dialtone's Avatar
Dialtone
changing brakes
Look on each side of the caliper for a diamond shaped opening. Inside this is a metal rail with a rubber filled center. Bend any retaining tabs towards center of opening and using hammer and punch, drive the retainer(s) rail out the back of caliper/housing assembly. Then, just lift the caliper off the rotor. Replacement is reverse. Don't worry if you damage/destroy them during removal. You can get new ones at most auto supply houses. Lube the slots during re-assembly (caliper slide rail grease) to allow the caliper to float (slide) during operation.
Dialtone
Old Jul 16, 2003 | 09:57 PM
Soulseeka's Avatar
Soulseeka
changing brakes
Good luck cause it's a pain... why did Ford do this?!
Old Jul 17, 2003 | 05:27 AM
marragtop's Avatar
marragtop
changing brakes
Also, when you put them back in, make sure you look closely at the shaping of the pin and the housing that it goes into. It will only go in one way, you cannot rotate it 180 degrees.
