Intro and V or X codes
Im new to Ex s but not to Ford. After turning in our 2011 Ford Explorer off lease we decided to go the no payment route and tracked down this 2002 Limited with 174k. We drove 4 hours to get it and paid $3000 and drove it home. Truck is from Georgia and is completely rust free and other than worn seat bottoms on the driver and passenger sides the truck in in great shape.
Repairs/Mods already completed
-New windshield ($200
-Swaybar endlinks ($140)
-4 door lock actuators( tried the tin foil trick it worked but didnt last long, ebay $40)
-new fluids and filters($100+-)
-Extended lift gate struts (Amazon $25) Im 6'8" and can stand under it
-20% tint on front doors and 5% sun band($80)
-knock off mickey thompson wheels 17x9 4.5in backspacing plasti dipped(FREE)
-285/70/17 Firestone Destination MT ($350 used)
-Rubber bet mat in cargo area and 3rd row(FREE)
-King Ranch steering wheel
Future Mods
-08 Diff cover and fluid change
-V or X codes front springs and modded Bs
-LED Light bar to replace factory fogs
-Phillips Xtreme headlight bulbs
-08+ trailer tow mirrors( have pass side need driver)
-black lug nuts( ebay $35 on order)
-Bilsteins
Overall love the truck and the wife actually enjoys driving it. Just got the wheels and tires mounted up last night. V or X codes seem to be more popular than lift kits and as I work for a Ford dealer I can get a deal on the springs. I like the fact that X codes give almost 3in of lift which is the look I want, but I'm concerned about the ride having the lighter v-10 versus a diesel. Do Vs ride that much better? It seems guys are only getting 1.5in of lift out of these looking for some input. Are x codes going to ride like a brick? Or am I better of modding the Vs to get the height I want?
If you are worried about too firm of a ride with the X codes then go with the Vs and some lift shackles. New v codes should net you 1.77" of lift with the V-10, add a set of 1.5" shackles to them and you will gain just over 3" total and still have a pretty smooth riding rig. I run a set of X codes with an extra leaf added to them, not exactly a Cadillac ride! Pretty firm ride here, just like I wanted
but definitely not for everyone.
Your truck is actually the one I was modeling mine after. I've always had lifted trucks so I was just trying to get an idea on the X codes up front. So firm but not bone jarring? You like the X codes correct?
Yep, I like my modded X codes, they ride very firm, some may say too firm but I wouldn't say they are bone jarring. You had mentioned not want too firm of a ride, that's why I suggested the Vs with shackle lift. Best of both worlds, nice lift and smooth ride!
RobRoss- You m ention maybe W codes if you had to do it again. Not enough lift out of the Vs? Not heavy enough?
From the spring chart it looks like Ws are about 400lbs less capacity than X codes but still give 2.5in of lift. This is about the same capacity difference in the stock Ex spring in a v-10 versus a diesel. I too was thinking about Ws but it seems not many people are running them. I am trying to avoid lift shackles for what reason other than my Jeep days and scary shackles.
I don't feel that it "jolts bobs and weaves" any different from my stock ride BUT my oe springs rode on the bumpers all the time
So I'm guessing lack of suspension movement makes me say that
I think I'm leaning towards the W code springs. Here is my rationale, diesel guys jump from D codes (4700lbs) to X-codes (6000lbs) a difference of 1300lbs and seem very happy with the results. Based on the chart V-10 C codes are rated at 4300lbs so if I jump up 1300 pounds like the diesel guys that would put me at 5600lbs which is a W code. Does this idea make sense? I want more lift than the V codes offer and it looks as though the Ws would give a V-10 about 2.75in of lift and Im concerned that the X codes would be to stiff. I can pick up W codes for $148 a piece a little cheaper than X codes and a few bucks more than the V codes.
Hoping to throw another leaf on the bottom to get about 3in of lift total. Any trackbar or swaybar links issues with 3in lift? Or can I run the stock stuff?
The (empty) ride with this set-up is firm, however, not in any way, intolerable.
That said-its not empty that the ride concerns me. Its while the rear is loaded w/ luggage and the boat is in tow that the spring mods & RSB become apparent.
