54 parking light wiring
Old Oct 25, 2014 | 09:00 PM
MIKEDEL's Avatar
MIKEDEL
I want to replace the pigtails for the parking lights but can't figure out how to remove the parking light. I removed the parking light bezel, lense and the headlight assembly but can't figure out how to remove the housing for the parking light. I've replaced all the headlight and parking light wiring because the insulation was brittle but had to leave the first 6" of the pigtail.
If anyone knows how to remove the pigtail I'd appreciate you telling me how.
Old Oct 26, 2014 | 07:17 AM
AXracer's Avatar
AXracer
Mid Fifty instructions says the bulb socket and wires push in/out of the light housing from the rear. They may be heavily corroded in after 60 years.
Old Oct 26, 2014 | 07:52 AM
MIKEDEL's Avatar
MIKEDEL
The problem is I can't get at the back side of the socket. I see the wires coming through the bottom of the headlight housing but can't find screws holding the parking light housing on.
Old Oct 26, 2014 | 08:20 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
There are 2 Phillips head screws (each) through the gravel pan. You have to get to them from under the vehicle (unless the gravel pan is off). Get some rust penetrator they usually are rusted solid.
Keep us posted.
Old Oct 26, 2014 | 08:58 AM
MIKEDEL's Avatar
MIKEDEL
Thank you very much. I took a look and can see the screw heads. Luckily I rustproofed the area in 1977 so I think I should be able to get them off.
flhx06
Dec 4, 2018 07:23 AM
mybigredford
Dec 13, 2004 08:13 AM
Billy Bronco
1978 - 1996 Big Bronco
Apr 4, 2003 10:40 PM
R. J. Pearson
1997 - 2003 F150
Aug 19, 2002 05:44 AM
