'02 Ranger Help
Old Jul 16, 2003 | 02:35 PM
CBear19's Avatar
CBear19
Unhappy '02 Ranger Help
my '02 Ranger XLT 3.0 L automatic has a problem.
When Rev-ing the engine in PARK or NEUTRAL, I do not get a steady VROOOM, at about 3,000 RPM on the gauge the VROOOM starts to break up (sounds like valves misfiring) into a shudder. I took it to service and they say this is completely normal (a prevention to stop me from blowing the engine, they say).
It's never done this in the past or I would have questioned it then. It's running rough and does not accelerate well on hills or as quick as it did when I first got it.
Any thoughts?
Please help.
TIA
Chris
Old Jul 16, 2003 | 03:15 PM
WXboy's Avatar
WXboy
'02 Ranger Help
No, that is not normal. How many miles are on the engine?
Old Jul 16, 2003 | 07:38 PM
CBear19's Avatar
CBear19
'02 Ranger Help
about 9,150 miles
Spoke with a co-worker with an '02 explorer and others with a ranger, and they said the rev will slow down steadily at high RPMs, but not a mere 3,000
i have the extended warranty plan, so I am not sure why these guys are jerking me around about this. I have a call in to the service manager, and I hope he can remedy the situation.
Old Jul 16, 2003 | 10:55 PM
superrangerman2002's Avatar
superrangerman2002
'02 Ranger Help
if you can try to get a second opinion from another Ford dealer, sounds like they are jerking your chain.
Old Jul 16, 2003 | 11:11 PM
Rancha9's Avatar
Rancha9
'02 Ranger Help
The dealership may actually be right. The older Taurus's (there's probably others, but that's all I've had experience with) had a rev limiter of 3000RPM in park or neutral, and yes, it's to keep you from screaming the engine with no load on it. As to what means it uses to control it, from the shuddering it sounds like it cuts fuel. I'd stay off that limiter, and as long as it'll redline in gear, I wouldn't worry to much about it. You can take it to another dealer and get a second opinion, but that's my .02.
Old Jul 17, 2003 | 08:02 AM
WXboy's Avatar
WXboy
'02 Ranger Help
Well, I've heard of these rev limiters in park and neutral too. But...this guy said his just started doing this and he also said it's been running rough under load when driving down the road lately. So that almost sounds like a problem with the ignition system.
Old Nov 18, 2004 | 05:13 PM
rtnye's Avatar
rtnye
Ranger 3000 rpm limit in neutral
I know this thread is a year old but if anyone is interested, my 01 Ranger does the same thing. I'm a mechanic and emissions testing manager and today I used my Ranger as a test using a test requiring me to rev the engine slightly above 3000; but my Ranger, which runs great, did cut out roughly at 3K in neutral. In gear (auto) the engine runs well past 3000 rpm. I was trying to verify that a limiter of any kind is on the vehicle by searching my factory manual for the Ranger or Alldata but with no luck.
Old Nov 18, 2004 | 05:51 PM
Dave257's Avatar
Dave257
YES it is normal. The engine is rev limited to about 3k in neutral/park on the 02 rangers(and other years)...
Dave
Old Nov 21, 2004 | 02:04 AM
Bluesyman's Avatar
Bluesyman
'02 Ranger Help
I have a 2001 Ranger XLT 3.0L , and its does appear to be normal for the rev limiter to cut in at about 3000 rpm
