Brake warning light??? Help.
Old Oct 21, 2014 | 11:47 PM
highboyhouston's Avatar
highboyhouston
Hey y'all I've got an issue i know someone on here knows how to fix. I have a brake warning light on the dash, that stays on whenever the key is on. Is it a pressure switch in the brake lines or something to do with the parking brake? I've bled my brakes like 5 times to try and get it to shut off, but it hasn't. Is it from the proportioning valve?
Thanks!!
Old Oct 22, 2014 | 08:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Has nothing to do with the parking brake.
C8AZ-2B264-A .. Brake Warning Lamp Switch / Available from Ford & auto parts stores.
Applications: 1968/79 F100/350, Bronco & Econoline / 1968/69 FoMoCo Passenger Cars.
This switch threads into the Brake Pressure Differential Valve that some people call a proportioning valve.
This switch is plastic and a notorious POS! Cracks develop within its threads causing brake fluid to seep out.
When this occurs, the warning lamp on the dash comes on...and stays on!
Old Oct 22, 2014 | 10:44 PM
highboyhouston
Thanks for your input NumberDummy! I've ordered the part, hopefully thats it!
Chris Thiessen
Jun 15, 2019 09:44 AM
gogreenwave
Jul 17, 2017 10:57 AM
EL_Musico
33
Oct 14, 2011 01:32 AM
CaptGuz
May 16, 2007 10:24 AM
Ford51
34
Dec 11, 2006 02:18 PM
