Some Dyno Numbers and Turbo info
#61
Well Keith got his new truck...
An SD PSD.... For a really good deal, so I cant blame him. I was fully expecting him to show in an 88 CC, and that truck turned out to be a POS...
That being said, I tried to goad him into letting me get the whole setup off of him to drop into smogie, but he seems adamant about putting it in an F150 or Bronco.... SOOoooooooo...
We'll see what comes here soon...
#63
So beyond this post, any other info on this project will go here:
https://www.ford-trucks.com/forums/1...l#post15480832
That is the transplant for Keith's engine and a whole build will be made of it...
In terms of covering the other aspects... I have found a work truck that will be the test subject that Keiths truck was being used for. It hauls heavy every day, all day, and will start from a stock N/A 7.3 and go from there. Its current drawback is that it has a C6, but I picked up a reman E4OD for it this weekend, so it can give reliable numbers in the quest from stock to wild. I will have a build thread for it as soon as I start the E4OD conversion... Soon.
#64
#65
I have 92 f-250 zf5 4x4 with fresh idi I redone. I was happy with truck but I through about 15k on her and she didn't go very far. Pumps turned up and had 088 ats turbo. I havent found performance parts so I as planning a Cummins swap. I read up and seen nmb2 and she pulled pretty good. So i figured build an idi instead of a Cummins. Was wondering what set up would be reliable and still have close numbers to your guy's..
http://www.idiperformance.com
They have builds on there site. The bronco build is also has a thread here.
Is the refreshed IDI in yours an IDI Turbo rotating assembly or an NA rotating assembly. The NA is fine for most setups, but as you will see from the Bronco thread, it doesn't hold up to extreme builds. The rods of an NA block ended up bending when constantly run at 50psi of boost.
#66
Look here for performance parts/kits etc
#67
The IDI turbo rods are beefier than the NA rods. R&D is working on machining a set of PSD rods that should be able to withstand all kinds of abuse.
#68
At that level there shouldn't be any issues. As far as how far you can push the boost on a NA block, i am not sure, other would be able to answer that better. I will say that i had not heard of any issues with putting a turbo on one until the Bronco build and 50 psi is A LOT of boost. Did you install head studs when you refreshed the engine? They are required for added clamping force if you are going above the 12-15psi range.
Thanks!
#69
No head studs. Just new Ford factory bolts. When I build the motor up I don't plant on running over 30-35 psi. I'll try injection pump, bigger turbo, headstuds, intercooler, maybe shaved please pistons. Hopefully that will wake her up. Like I said I was looking for reliable build.
Thanks!
Thanks!
#70
Thanks!
Thanks!
FORDF250HDXLT
51
06-10-2011 05:35 PM
Dr.B
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
09-18-2008 12:11 PM
Jefftopgun
05-25-2005 09:13 PM
