Aerostar Ford Aerostar
LEAN BANK ONE
Old Nov 13, 2014 | 08:02 PM
xlt4wd90's Avatar
xlt4wd90
The vents turning to defrost on hills indicates the AC controls are losing vacuum when the engine is under load. That could be a check valve problem, or your vacuum reservoir is leaking.
Old Nov 13, 2014 | 08:05 PM
99f350sd's Avatar
99f350sd
Was a bad check I hope...gonna try carb cleaner soon.
Old Nov 14, 2014 | 10:00 AM
jetfiremuck's Avatar
jetfiremuck
Sounds like the booster. The booster is a dual diaphram and mine started the same thing. It got so bad (me lazy) i could get the engine to stumble and die almost by moving my foot slightly on the pedal. It goes bad long before you hear the hiss. Might as well do master cyl as your at it. I had the same lean code/ registers going to defrostvetc.
Old Nov 14, 2014 | 05:03 PM
99f350sd's Avatar
99f350sd
Blocked the booster hose didn't cure anything...
Old Nov 16, 2014 | 09:15 PM
99f350sd's Avatar
99f350sd
Found it
So its the air tube from the egr valve. The seal at the plastic intake....Any ideas?
Would a fel pro 71202 work?
Dick
Old Nov 16, 2014 | 10:15 PM
93nighthawk's Avatar
93nighthawk
Dick
Looking at the catalog, it would take a Fel Pro 72266.
Old Nov 17, 2014 | 05:26 AM
99f350sd's Avatar
99f350sd
Thanks much. I couldn't find that....
Old Nov 17, 2014 | 07:24 AM
99f350sd's Avatar
99f350sd
Gonna get one of each and see what seems better.. Or maybe use both.
Old Nov 18, 2014 | 02:49 PM
99f350sd's Avatar
99f350sd
Wahhlaa Fixed...just when you thought the old 96 couldn't run any better....Runs like new. I used both the oring and the oem gasket. felpro 71202 and felpro 72266.
It aint gonna leak and i'll bet my green 96 could use them. Its not real hard getting at that seal you just have to be able to get the bolts out....The ac comp has to come out and be laid it aside. dipstick nut and pull stick just nuff to go over stud don't yank out of block.
Now the stud has to come out where the dip stick was fastened. Good luck. mine was ok because I did an intake gasket a few years ago. From the wheel well I removed the two egr bolts. Next I grabbed the egr and flexed it out of the way to get the pipe out.
The seal didn't look too good...I put the new oem on then the green oring and put everything back together.
I'll bet many 4.0L have this problem.. A little carb cleaner will tell or heat to defrost up a hill.
Thanks Guy's
Dick
Old Nov 22, 2014 | 06:46 PM
99f350sd's Avatar
99f350sd
Now that the engine runs good and I have the major vacuum leak fixed I did notice going up a hill the heat diverted to defrost....Tank and check valve check ok. Don't know what to look for or how to check the two lines that go into the dash area from outside in the engine compartment. Checking these with a vacuum pump depends on where the switches are turned..I do have my green van to compare to..but.
All three of my vans go to def when on a hill. The green mint one not all the time. grrrr. Vac tank is pretty small.
Old Nov 26, 2014 | 09:53 AM
Jose A.'s Avatar
Jose A.
sounds like a cracked vacuum tube going to the RECIRCULATE valve/actuator, near where that check valve is also connected to the vacuum tubes.
Old Nov 30, 2014 | 12:23 PM
jetfiremuck
Originally Posted by 96_4wdr
Only Bank 1 on the Aero V6s.
OBDII advanced PCM computer in the '96 on still outputs Bank 2 data, but random gibberish.
V6 and V8 with dual exhaust and dual CATS have both Bank 1 and Bank 2 real time data.
Bad wires would pop misfire codes.
You get to start the great vacuum line hunt, they get damaged and knocked off replacing the plug wires.
That Christmas vacuum tree has never gave me any good presents.
Shame Ford never bred a line of 2" midget auto mechanics just for the Aero.
Started the van the other day for the late 300 mile trip home . Engine stalling at idle wouldnt idle. Any way had to power brake in traffic until I hit 95 ok at speed but at1k rpm would miss and stumble. Long story short it had popped the vac hose from the intake next to pcv hose. Rubber nipple lost its tension. I had read your reply some days earlier. Thought it was plugs wiring.
Old Nov 30, 2014 | 09:13 PM
  #28
99f350sd's Avatar
99f350sd
I did a vac check of all the hoses they seem to be fine. Van doesn't have enough miles to have the lines go bad yet it seems.
Dick
r stene
1983 - 2012 Ranger & B-Series
Jan 26, 2011 01:02 PM
rpm5099
3.0L V6
Jul 27, 2010 05:06 PM
1994 Ford MN
Mar 14, 2010 01:32 PM
B-Aerostar
Aerostar
18
Aug 14, 2006 05:58 PM
imnotdrunk79
Oct 2, 2005 12:39 AM
