Smogged up FE
Old Oct 18, 2014 | 06:32 PM
TBird Larry's Avatar
TBird Larry
Smogged up FE
I bought a complete running FE with all the accessories including A/C, PS brackets, pulleys and belts still on the front and a flex plate with torque converter for a C-6 on the rear and a Cool Set of Headman Headers. Didn't see the truck because it was scrapped but it was a 70's F-250 vintage in fact the guy told me it was a 74. I don't know if it is a 360 or a 390. All the exhaust ports have that nice gray color from a good burn and not an oil burner.
It has an EGR valve under the carb (2 barrel) and you can see where some vacuum hoses were disconnected. The manifold is D8TE8425A and the EGR has a D4 (74) date code so I think someone changed the manifold as it is a 78 vintage. There was no air pump for the smog nor does it have the air injection holes in the heads for an air injection pump. I don't know if this was originally a California truck and I think 78 has all the smog stuff for Calif. so I think this engine was put together from parts.
Anyone know more about the smog equipment the FE's were burdened with and the Calif. smog stuff?
I am going to use the brackets, pulleys and other hardware from the front for the engine in my 65 F-100. My PS is all installed and I purchased a steering U-Joint from Helix with a 36 spline and a DD on the other. I took my steering shaft over to the machine shop and he milled the DD end so it would fit the U-Joint. I feel safer now without the rag joint.
I intend to pull the valve covers and pan for inspection and pull the intake to take a look and to replace the intake gasket as it has a little seepage. Maybe I'll pull the heads and take a look and I'll measure the stroke to see if it could be a 390. If all looks good I will sell it as a runner and if not a core. Maybe I'll find a bell housing and a starter and fire it up.
Old Oct 26, 2014 | 09:56 PM
HIO Silver's Avatar
HIO Silver
This article might be able to illustrate and answer to your questions: Ford FE Smog-Legal Horsepower - Classic Trucks Magazine
The intake has a D8 casting? The last year for the FE engines was 1976.
I'm a USN vet... AT2.. worked on P3 Orions and MH-53E minesweepers.
Old Oct 27, 2014 | 10:21 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Probably a D3 intake. Or even a '6' ...
2-bbl FE from 1974? 99% willing to bet it's a 360
Martin Torres
Sep 23, 2016 12:08 AM
smokenchoken
20
Jul 30, 2013 11:52 AM
bamaf150
Jan 16, 2011 09:39 PM
welder79
Nov 11, 2008 01:23 PM
385seriesHemi
Dec 21, 2006 03:54 PM
