Front axle question
Old Oct 17, 2014 | 04:39 PM
tbugher62's Avatar
tbugher62
Front axle question
What front axle came on the 1994 Ford F 350 4x4 truck's,the dana 50 or 60 ?
Old Oct 17, 2014 | 04:47 PM
bashby's Avatar
bashby
60........
Old Oct 17, 2014 | 07:17 PM
eakermeld's Avatar
eakermeld
Dana 60 ball joint style.
Old Oct 17, 2014 | 07:33 PM
eagle275's Avatar
eagle275
Is it the same for a 1996?
Old Oct 17, 2014 | 07:36 PM
tbugher62's Avatar
tbugher62
Thank you guy's.
Old Oct 17, 2014 | 07:37 PM
eakermeld's Avatar
eakermeld
Almost. The brake calipers are different. If you are shopping for one, the later style calipers are better than the older ones. Here is some very good info on these axles.
BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
Old Oct 17, 2014 | 07:45 PM
LeoJr's Avatar
LeoJr
tbugher62, ya got something in the works?
Old Oct 17, 2014 | 11:13 PM
eagle275's Avatar
eagle275
Thanks! Saved it and started reading. BTW, what are the rears?
Old Oct 18, 2014 | 04:59 AM
tjc transport's Avatar
tjc transport
i ain't rite
rear is a sterling 10.25.
Old Oct 18, 2014 | 12:46 PM
LeoJr's Avatar
LeoJr
I think I read that the caliper mounting brackets interchanged? So if you have a 95 and newer D50 and you are swapping in an older 94 and older D60 you could swap the caliper mounting brackets and keep your newer brakes. Somebody would need to fact check me though.
Old Oct 18, 2014 | 01:16 PM
Coutu's Avatar
Coutu
Sorry to hijack... but what the front and back axles of a 91' F-250 diesel 4x4?
Old Oct 18, 2014 | 02:48 PM
tjc transport
i ain't rite
front should be a dana 50 IFS, rear is a sterling 10.25.
Old Oct 18, 2014 | 04:00 PM
eagle275's Avatar
eagle275
Ok, so a 1996 F350 4X4 Std cab LB w/460 SRW has a front Dana 50 , and rear is a sterling 10.25?
Old Oct 18, 2014 | 04:07 PM
tjc transport
i ain't rite
no. all F-350's after mid year 1985 to 1997 got a dana 60 solid axle. F-250 got either the dana 44 or dana 5o IFS.
Old Oct 18, 2014 | 06:29 PM
Diesel_Brad's Avatar
Diesel_Brad
Could be either a semi float sterling 10.25 and Dana 44 HD TTB
OR
Full float sterling 10.25 and a D50 TTB
It SHOULD have a Dana 60 solid axle in the front unless someone swapped it out
