6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DPF Delete question
Old Nov 6, 2014 | 05:10 AM
  #31
BROWN DOG KTM's Avatar
BROWN DOG KTM
Originally Posted by SANDDEMON08
... (normally 725 RPM for manual, 650 RPM for auto) ...
Did Ford put a Manual Trans behind a 6.4 ?
I've Never seen one
Old Nov 6, 2014 | 12:42 PM
  #32
SANDDEMON08's Avatar
SANDDEMON08
I've Never seen one
Yep the 6.4 had the manual option the reason you don't see many is because there was less then 5-6% of all 6.4's where equipped with the manual trans between 08-10.
If you find one its probably the strongest version ZF6 you can find.
Old Nov 6, 2014 | 03:06 PM
  #33
CampSpringsJohn's Avatar
CampSpringsJohn
I have a friend that has a 6 speed in an F250 6.4
Old Nov 8, 2014 | 04:36 PM
  #34
caprang's Avatar
caprang
subscribing to hear the results. Im starting to evaluate different tuners myself
Old Nov 9, 2014 | 07:02 PM
  #35
aphotic26's Avatar
aphotic26
My transmission just starting to shift weird right after I did the programming though...no codes.
My FIRST tank of fuel with no trailer I received an extra 220+ KM to the tank. Enough said.
Old Nov 10, 2014 | 02:30 PM
  #36
Tawn's Avatar
Tawn
Does anyone offer a complete "kit" i.e EGR delete, DPF delete pipe, tuner and ALL the required parts and hardware?
Mine is just about out of warranty and I plan to go the delete & tune route but I don't want to order the DPF delete pipe from company 'A", the EGR delete from company "B" and the tuner from someone else.
Old Nov 10, 2014 | 06:53 PM
  #37
Greg B's Avatar
Greg B
There are many companies that offer the required parts and tuners to do the deletes. Just go on Google and type in DPF Delete and they will pop up. To my knowledge no company manufactures every component required to delete. But the aftermarket retailers all offer what you need. You should be able to order everything you need from one retailer.
Old Nov 12, 2014 | 07:45 AM
  #38
BROWN DOG KTM
Originally Posted by aphotic26
My FIRST tank of fuel with no trailer I received an extra 220+ KM to the tank...
How many extra Miles ?
Old Nov 12, 2014 | 06:58 PM
  #39
CampSpringsJohn
220 X .6 = 132 So, approximately an extra 130 miles.
Old Nov 13, 2014 | 12:19 AM
  #40
73fan's Avatar
73fan
I have a friend like that too!
NEXUS 4. IB AutoGroup
Old Nov 14, 2014 | 08:47 PM
  #41
aphotic26's Avatar
aphotic26
I save $55 per tank, fuel up twice third is completely paid for from savings. (100 litre tank).
Old Nov 15, 2014 | 06:38 PM
  #42
parkland's Avatar
parkland
Originally Posted by Greg B
Glad the idle issue is taken care of. As to the transmission shifting, the programmer didn't do anything to the transmission strategy. It's still all factory Ford.
That is not entirely true.
While the transmission might have a stock calibration, the line pressures and shift information is based on several inputs from the PCM. Since the tuning for the engine is now new, the transmission will be getting slightly different information to base it's shifting from.
Chances are, it will figure itself out, as the transmission "learns" as you drive. There are some ways to make it learn faster, like wide open throttle runs.
The factory system adjusts itself for clutch pack wear, driving style, etc. Chances are that all will be fine just after driving a bit.
Is it just a shift flare? Like when it doesn't shift fast enough, or is it binding and stumbling?
Old Nov 16, 2014 | 11:30 AM
  #43
BROWN DOG KTM
This would mean he improved 3-4mpg ....
I'd say 1 - 2mpg improvement would be more realistically achievable
Old Nov 17, 2014 | 07:38 PM
  #44
Greg B's Avatar
Greg B
Browndog, I loaded the 70 hp tune from my Gearbox Z DPFR+ and picked up 3-4 mpg highway. I was getting 15.5-16 mpg highway stock and am getting 18.5-19.5 highway with the tune. I even hit just over 20 mpg a couple of times. So it's doable. A lot hinges on how you use the skinny pedal. That's calculated. I don't know what the lie-o-meter says. I never look at it.
Old Nov 17, 2014 | 07:44 PM
  #45
Greg B's Avatar
Greg B
Brown Dog, I picked up 3.5-4 mpg with the 70hp tune from my Gearbox Z DPFR+ tuner. I was getting 15.5-16 hwy stock and am now getting 18.8-19.5 mpg hwy. I have hit just over 20 MPG a couple of times, but that's not the norm. That's all hand calculated. I don't know what the Lie-O-Meter says as I never look at it. So it's possible. A lot of it has to do in how you use the skinny pedal.
