Wrong Steering Wheel
Old Oct 15, 2014 | 09:40 PM
kboldin's Avatar
kboldin
So looks like I have the wrong wheel on my 73 F250, if anybody can identify what I have and give examples of an OEM wheel that will fit correctly (turn signal functionality, horn etc…) I would appreciate it! My guess is that it’s a 67-72ish wheel?
Gap, wheel to hub.
Backside.
Frontside.
Horn button.
Two spoke.
Old Oct 15, 2014 | 09:45 PM
HIO Silver's Avatar
HIO Silver
'Not a 67-72 wheel IIRC.
Any PNs on it? Post it up.
Old Oct 15, 2014 | 10:16 PM
kboldin's Avatar
kboldin
E6HT-13A805-AA on the horn button and what looks like 1-6h7-3600 B on the wheel.
Old Oct 15, 2014 | 10:19 PM
HIO Silver's Avatar
HIO Silver
E6HT...
E means 1980s
6 means year six... therefore, 1986
H is a medium/heavy truck 1983-later
T means "Heavy Truck Engineering"
Bob's your uncle!
Old Oct 15, 2014 | 10:30 PM
kboldin's Avatar
kboldin
So that likely came off a BIG work truck, ala industrial truck. Alrighty then! Appreciate the help on that one!
Old Oct 15, 2014 | 10:37 PM
HIO Silver's Avatar
HIO Silver
Sho' thang.
Here's a page for PN reference: http://www.classicmustang.com/decoding_part_numbers.htm
Old Oct 15, 2014 | 10:46 PM
kboldin's Avatar
kboldin
HIO nailed it, 1988 F600 Box truck. http://www.interschola.com/template/...7/img_7942.jpg
Old Oct 15, 2014 | 10:49 PM
kboldin's Avatar
kboldin
So will any 73-79 wheel work? Did they change the steering column part way through? Likely go to the wreckers this weekend and see if I can pick a part. I have a new turn signal switch on the way, so no rush but the right wheel is going back on!
Old Oct 15, 2014 | 10:52 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
A 73-79 should fit, the older ones are bigger in diameter and some where around 77 they changed then from 2 single prong horn wire set up to a multie plug connector in a newer late 77-79 cruise control center.
FYI a new repo can be $$$$.
The rest of your column looks stock to the correct year.
Old Oct 15, 2014 | 11:41 PM
HIO Silver's Avatar
HIO Silver
I know a 78/79wheel will fit but the turn signals won't cancel... I have one in my 73 and usually forget to cancel 'em cuz I can't hear the turn signal flasher and my dash indicator is dim. 71-77s without speed (cruise) control will swap...
A bare (no horn pad) 71-77 repro retails for about $250.... I picked up an NOS wheel off of Ebay for $160 a few months ago... it even came with a horn pad worth another $100 in repro.
Old Oct 16, 2014 | 12:31 AM
kboldin's Avatar
kboldin
My truck is a weekend work truck for now, I'll likely pick up a second hand wheel at the wreckers. I'll look for an early year truck (73-77) and go from there. Certainly appreciate all the help!
Old Oct 16, 2014 | 01:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Marked with ID engineering number: E6HT-13A805-AA = Ford part number: E6HZ-13A805-A .. Horn Button-Ford oval 3 3/8" diameter = 1987/89 all 600/900 series trucks (except CF600/800 Tilt Cabs).
1967/70 F100/350's & 1966/73 Bronco's have a 3 spoke 17" diameter steering wheel using either a horn ring or horn button.
The original 1971/73 F100/350 2 spoke steering wheels were available in colors. In 1974, Ford replaced them with this:
D4TZ-3600-A .. 2 Spoke Steering Wheel-Black / Reproduced
Applications: 1971/77 F100/350 - 1974/77 Bronco - 1975/77 Econoline (except 1975/77 F100/350 & Econoline with Speed Control).
Pic says 1973/ .. but 1978/79's use different steering wheels, horn pads (and T/S switches).
1973/77 F100/350: THREE different T/S switches: D3TZ-13341-A M/T / D3TZ-13341-B A/T / D5TZ-13341-B 1975/77 with Speed Control
1971/77 F100/350 (1974/77 Bronco, 1975/77 Econoline) horn pads are the same (except 1975/77's with Speed Control). There are two types:
Black camera case finish: Custom, Sport Custom (1970/72) & Ranger / Walnut wood grain finish: Ranger XLT/Econoline Chateau/Bronco Sport.
Old Oct 16, 2014 | 01:25 AM
HIO Silver's Avatar
HIO Silver
Also check Broncos and Econolines of the same vintage... if ya can find a Bronco in the yard. I've only seen one in the yard recently and it was rusted beyond belief... musta come from a coastal CA town cuz it was rotten.
Old Oct 17, 2014 | 03:20 PM
kboldin's Avatar
kboldin
Had good luck today! Went to the pick and pull and grabbed a pretty fair steering wheel and horn pad (two different trucks and one of them was a u-haul) I also found a clip for the turn signal return (if I need it). Got a dome light cover, cigerette lighter, drive selector cover, and an almost perfect dash pad with one small bubble on the passanger side. I only had a few hours to work with before work today but I'm really happy with what I found! All of it came to $42.65 (WOW!!)
Small bubble in the corner.
Old Oct 17, 2014 | 04:31 PM
NumberDummy
I assume you are aware that this is a 1978/79 steering wheel.
