T18 Rebuild question
Old Oct 15, 2014 | 01:46 PM
PancakeF150's Avatar
PancakeF150
I am sorry I didn't take picture of the part in question. Looking at the outside of the top cover of my T18 there are 3 caps on each end of the cover. They look like freeze 3/4 inch plugs put in backwards. What is behind those and should they be addressed in a "rebuild"?
Thank you.
Old Oct 15, 2014 | 04:20 PM
OldMetal's Avatar
OldMetal
Those will be the shift rails that the shifting forks slide on and usually are not a problem just check them for smoothness and play , if things were shifting ok you should be fine with them as is
Old Oct 15, 2014 | 05:39 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Couple of T-18 diagrams in here.
https://www.ford-trucks.com/forums/1...then-some.html
kupiec20
Apr 26, 2016 08:56 PM
SACGNS
Jul 2, 2009 05:37 PM
pruitt
Mar 4, 2009 08:06 AM
logan_85
May 2, 2001 09:48 AM
