6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
P0400?
Old Oct 14, 2014 | 12:35 PM
RM2738's Avatar
RM2738
P0400?
Couldn't find much info. It's on my buddy's 2008 6.4.
Old Oct 14, 2014 | 05:03 PM
slowmans's Avatar
slowmans
P040D?
P040D Exhaust Gas Recirculation Temperature (EGRT) Sensor A Circuit High
Old Oct 14, 2014 | 05:12 PM
muntu's Avatar
muntu
P0400 Exhaust Gas Recirculation Flow
Old Oct 14, 2014 | 05:21 PM
RM2738's Avatar
RM2738
Originally Posted by slowmans
P040D?
I'm sure that's it. He read it upside down. That's the sensor that's on the up-pipe behind the passenger fender well?
Old Oct 14, 2014 | 05:58 PM
slowmans's Avatar
slowmans
Honestly I have no idea, PM Cheezit...
Old Oct 16, 2014 | 10:18 PM
GHeTTo JOe's Avatar
GHeTTo JOe
<table class="ADVV1-HotlineArchives-Whites" height="342" width="1043" cellpadding="0" cellspacing="0"><tbody><tr><td class="ADVV1-HotlineArchives-LeftRuledRows">
</td> <td class="ADVV1-HotlineArchives-RuledRows"> 1. EGR and exhaust gas temperature sensor codes will many times put the PCM into "limp" mode. Fix this code before further diagnosis.
2. Access the EGR temperature sensor A for circuit tests. The sensor is mounted in the exhaust pipe that connects to the rear of the Right Hand (RH) exhaust manifold. The harness connector should be near the rear of the RH valve cover just forward of the rear engine lifting bracket. The sensor is normally easier to access through the wheel well.
3. At the two pin connector, the Brown wire is the 5 volt reference to the sensor. The Green and White wire is the ground for the sensor. The code P040D suggests the voltage on the sensor is at or above 4.65 volts.
4. Leave the connector plugged in, turn the key on, backprobe the Brown wire with your volt meter. If the voltage is at or above 4.65 volts, backprobe a good ground to the Green and White wire.
5. If the voltage comes down with a ground supplied to the Green and White wire, repair the ground circuit or pin.
6. If the voltage remains at or above 4.65 volts, suspect an open EGT sensor or bad connection.
yes it is
</td></tr></tbody></table>
Old Oct 21, 2014 | 08:53 PM
cheezit's Avatar
cheezit
P040d sensor in passanger pipe. Remove fender liner. They do tend to get stuck in the pipe, retap the hole if needed.
Oakley61
May 6, 2013 01:00 PM
kjg26
19
Jun 5, 2007 10:22 AM
Mountaineer Boy
Aug 27, 2005 11:13 PM
bigpowerstroke
Apr 19, 2004 06:21 PM
