351 specs
Old Jul 15, 2003 | 09:39 PM
Chris_ce's Avatar
Chris_ce
351 specs
Planning on rebuilding my 351w ho.Where can i find all the specs?Like the cam and lifter specs and how big I can go.
The motor is a 351w ho out of a 87 bronco.
Old Jul 15, 2003 | 10:49 PM
bronc90's Avatar
bronc90
351 specs
check a chiltons or haynes in the rebuild section. or if you can wait till tomorrow i will look it up for you in my garage
Old Jul 15, 2003 | 10:53 PM
bronc90's Avatar
bronc90
351 specs
try this .
this was said to be run by chilton
Old Jul 15, 2003 | 11:15 PM
Jimbo302's Avatar
Jimbo302
351 specs
What exactly are you looking for? If you are running an overly high lift and duration you should clay it anyway.
Old Jul 15, 2003 | 11:20 PM
Chris_ce's Avatar
Chris_ce
351 specs
Wanting to go with a little bigger cam and rocker arms.
Old Jul 16, 2003 | 01:01 PM
Jimbo302's Avatar
Jimbo302
351 specs
So you are just looking for cam suggestions? Depends on how you are going to use it, how much your truck weighs, your tranny and what ratio gears, the intake and heads you will be using, etc.
Old Jul 16, 2003 | 06:45 PM
Chris_ce's Avatar
Chris_ce
351 specs
Here are the details for my truck.
351w ho,c6 trans, 3.55 rear ends.
Truck will be used for weekend driving and towing but still want to be able to 4x4 and spin some tires.
I am looking for a cam and maybe rocker arms.
wanting to stay as cheap as posable thats why I'm looking at rocker arms.If i have the money after my block work and rebuild kit I plan on a port,polish and three angle valve job.
What I'm looking for is any info that this board will feel is helpful to me.I would like to get around 300 hp motor is stock at 220.
Old Jul 16, 2003 | 07:05 PM
Brian460's Avatar
Brian460
351 specs
What size tires?
Old Jul 16, 2003 | 09:59 PM
Chris_ce's Avatar
Chris_ce
351 specs
31.10.5015
