Rugermack's build thread
Old Mar 26, 2015 | 09:05 AM
  #31
rugermack's Avatar
rugermack
I live in arizona so road salt isn't a problem. Its just black gloss rustoleum. Holds up pretty well here.
Old Mar 26, 2015 | 02:43 PM
  #32
xrsfsho's Avatar
xrsfsho
Which rear brake line did you get? And how much loner is it?
Old Mar 26, 2015 | 05:05 PM
  #33
Fastback460's Avatar
Fastback460
That is a great stance for that truck. Looks really good
Old Mar 26, 2015 | 05:39 PM
  #34
rugermack's Avatar
rugermack
The brake hose came from Rough Country, says its stock lenght because back is only lifted 2", when I replaced it, the new one(from RC) was about 1.5" longer.thanks Fastback, the front still needs to settle a tad. Its sitting with the back tilted down a Hair.
Old Mar 26, 2015 | 05:54 PM
  #35
xrsfsho's Avatar
xrsfsho
Ok ill look into that brake line. My f150 has the RC 4in kit two with the blocks. The rear was lower still after several years (PO put it on). I just recently jumped to a 1in larger block to compensate for the rear being lower. Awesome truck. I would love yo run 35s on mine but i only have 3.55 gears right now with 33s and i dont want to imagine 35s.
Old Mar 26, 2015 | 06:48 PM
  #36
Redneckfordf2502002's Avatar
Redneckfordf2502002
Those 35s look great on their with a 4" lift.
Trav
Old Mar 26, 2015 | 09:17 PM
  #37
K9Kodi's Avatar
K9Kodi
could you run 93ish body style door panels?
Old Mar 26, 2015 | 10:13 PM
  #38
Bruners4's Avatar
Bruners4
Front end is cleaned , repainted, resealed, all new bearings, balljoints, all ujoints, steering, suspension, Energy Suspension bushings. Steering is now parrallel after tie rod flip and drop pitman.
I'm interested in how you did your tie rod flip. Did you use some bushings?
Old Mar 26, 2015 | 11:18 PM
  #39
rugermack's Avatar
rugermack
bushings are from Jeffs bronco graveyard, 7 degree, just ream(knuckles) them til bushing fits then bolt them up. My steering is parallel after install with drop pitman also.
Thanks trav
Old Mar 26, 2015 | 11:24 PM
  #40
rugermack's Avatar
rugermack
F150 Knuckle Conversion Sleeves
Item Number: 12775
Old Mar 27, 2015 | 08:22 PM
  #41
Redneckfordf2502002
He would have to change the wing vent windows out for 92-96 wing vent windows.
Also not sure if it would clear the dash.
Trav
Old Mar 27, 2015 | 09:24 PM
  #42
Bruners4's Avatar
Bruners4
Item Number: 12775
Thanks! Just what I'm looking for to complete my front end!
Old Mar 27, 2015 | 10:29 PM
  #43
Pfree87's Avatar
Pfree87
Nice truck its always nice to see an old truck getting a new lease on life
Old Mar 28, 2015 | 09:07 AM
  #44
rugermack's Avatar
rugermack
worked great for me, should eliminate the bump steer. Now you have to find a 7 degree reamer.
Old Mar 28, 2015 | 09:10 AM
  #45
rugermack's Avatar
rugermack
Me too, and one that is paid for, I don't tow anymore so time to sell both deisels. I wanted a paid for dependable truck.
